Carburetor ID
this thread has 0 replies and has been viewed 329 times
Old 12-26-2018, 05:21:28 PM
Default Carburetor ID
Bought this carb recently. It looks Kingston but no tag or markings.
- throat - 1-7/16
- flange holes 2-11/16 apart
- throttle butterfly in throat
- air intake - 2-3/8 od; 2-3/16 id
- float bowl - 3-3/4 od; 3-9/16 id
- brass float - float valve in carb body
- one fuel adjusting valve goes down into the long stem attached to the nut which holds float bowl on
- other fuel adjusting valve goes into below butterfly
- no weighted air valve like Kingston Model L
It is a good looking carb. I hope to give it a try some day.
Any thoughts?
Thanx.
ID:	325153   Click image for larger version
ID:	325154   Click image for larger version
ID:	325155   Click image for larger version
What is this Carburetor? Tom Adkins Antique Gas Engine Discussion 5 01-05-2017 04:55:41 PM
Carburetor ID Curtis Small Air Cooled Gasoline Engines 4 12-21-2016 07:50:10 PM
Carburetor help cobrajetken Garden Tractors / Mowers / Scooters 3 11-02-2015 10:31:04 AM
ihc m 1 1/2 HP carburetor maytag340 Antique Gas Engine Discussion 4 07-12-2013 03:25:08 PM
Carburetor John Davis Antique Gas Engine Discussion 3 03-11-2006 09:48:15 AM
