Fordson F Head Identification Needed
this thread has 3 replies and has been viewed 433 times
Old 12-29-2018, 03:11:43 PM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default Fordson F Head Identification Needed
does anyone know what year this fordson tractor model F head is from? only castings I can find is " XX R.R.1" thank you for your time and knowledge.
ID:	325358   Click image for larger version
Old 01-01-2019, 07:08:34 PM
DTurner DTurner is offline
Default Re: Fordson F Head Identification Needed
Sorry ,nice head ,is the spark plug hole tap to 1/2 NPT ?
Old 01-15-2019, 12:59:27 PM
Steve Welker Steve Welker is offline
Firewood Guy,
The sunken plug head like that was used up thru 1925. The RR1 is commonly believed to signify the River Rouge plant. Since production was switched here in 1921, I would say the head is from 1921 thru 1925. It will physically bolt on the block from 1917 thru 1952, but water passages will only line up correctly from 1917 thru early 1927. Around s/n 662,000 the water passages around the valves changed an the hole in the head surface also changed.
And Yes, spark plugs in this head have 1/2” pipe thread.
-Steve
The Following User Says Thank You to Steve Welker For This Post:
Old 01-15-2019, 07:38:20 PM
Steve, Thank you for the helpful information.
Different Fordson Head Steve Welker Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 07-05-2017 03:49:51 PM
Fordson Head Part Number and Axle Casting Numbers Nik M Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 05-31-2017 04:59:52 PM
Fordson Identification please audiobull Antique Farm Tractors 15 08-19-2015 02:37:23 PM
Fordson F serial number on cylinder head Herbert Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 03-14-2015 01:22:09 AM
Fordson ID needed David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 09-09-2009 09:06:16 PM
