Steel Wheel Cleats
this thread has 16 replies and has been viewed 1211 times
Old 01-02-2019, 10:47:21 AM
50supera 50supera is offline
Default Steel Wheel Cleats
Hello, New territory for me since I normally work with rubber tires. I will be working on a 15-30 MD on steel. The wheels have no cleats. I have seen pictures of tractors with individual cleats and some with what looks like angle iron cleats that are at an angle across the wheel. Were these for different soils or just operator preference?
The Following User Says Thank You to 50supera For This Post:
Old 01-02-2019, 11:07:25 AM
Default Re: Steel Wheel Cleats
Most or all 15-30's used lug style cleats on the rear wheels with guide bands on the front.Any pictures?
Old 01-02-2019, 12:40:20 PM
Mike in NC's Avatar
Images: 74
The angle irons helped with traction. I know on a 22-36 that a friend had, the cleats did not get as much traction as the angle irons.
Some people put the cap from a recap on the wheels so they do not do damage to the surface the tractor is driven on.
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Old 01-02-2019, 12:50:40 PM
You need to get a copy of the operators and parts manuals for that tractor.The parts book should show what types of cleats and lugs that were used on the 15-30
www.binderbooks.com
https://www.binderbooks.com/ihearlytractormanuals.html
Old 01-02-2019, 02:48:20 PM
No pictures yet. I will post ASAP. I've got to do a little "logging" to get the tractor out and we are very wet right now. I have purchased a parts book off of ebay just waiting on it. I'm pretty sure it's a 1926. It will need a lot of TLC.
Old 01-02-2019, 07:32:06 PM
www.thefordsonhouse.com
Old 01-07-2019, 06:02:36 PM
Photo Re: Steel Wheel Cleats
Here's a picture. Block S/N 31075. I got my parts book today too. My 36 JD AO looked about like this when I got it.
ID:	325917   Click image for larger version
The Following 6 Users Say Thank You to 50supera For This Post:
Old 01-07-2019, 09:28:59 PM
Early 15-30...1925 or maybe earlier. If you crawl under the tractor there is a date on the bottom of the main casting that will get you in the ballpark. Lots of early characteristics on this one...has the heavier road wheels also.
The Following User Says Thank You to Mark Schneider For This Post:
Old 01-07-2019, 10:50:17 PM
Thanks Mark.
I found the casting date but, I can't get under it far enough to read it. Going by the block s/n it's a 1926. Lot's of questions to come.
Old 01-07-2019, 11:00:01 PM
Moline Moline is offline
if you want i could make you a set of cleats like these.
ID:	325934   Click image for larger version
The Following User Says Thank You to Moline For This Post:
Titan 10-20 Rear Wheel cleats PMR02 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-30-2018 05:02:48 PM
Rubber wheel cleats Billy Donegan Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 01-09-2014 07:53:26 PM
John Deere D Steel Wheel Rubber Cleats? sdwatt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 07-27-2012 01:15:09 AM
John Deere Steel Wheel Cleats or Lugs redbarn Antique Farm Tractors 7 01-29-2012 10:33:59 PM
16-30 H Oilpull Cast Wheel Cleats Oilpulled Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 03-29-2009 11:53:48 PM
