Large Piston Ring Expander
this thread has 5 replies and has been viewed 967 times
Old 06-17-2017, 11:02:07 AM
JBoogie's Avatar
JBoogie JBoogie is offline
Images: 241
Default Large Piston Ring Expander
Hello,
What is everyone using for large ring expanders? I'm talking for pistons 6-12 inch diameter. I ordered one from McMaster that goes to 7 1/2, it's a pliers type. I contacted the manufacturer (Zimm in Chicago) and they make larger ones but they are a hell of a lot more that the $18 I paid for the pliers type. All of the rings I deal with are different widths and they're step cut. Open to suggestions.
Old 06-17-2017, 10:03:25 PM
Rob Charles Rob Charles is online now
Card Sponsor
Default Re: Large Piston Ring Expander
I use a pretty large Mac retaining ring pliers. They are about 16" ish long. Rob
Old 06-18-2017, 10:38:47 AM
TomBall TomBall is offline
Not sure what pistons you are removing rings from. I remove and install rings on large antique gas engines with strips of heavy sheet metal cut in strips about 1/2 or so inch wide and several inches long. I just keep sliding strips under the ring and around the piston until the ring is above the ring groove, then just slide them off. Takes longer I'm sure but it works for me. Never tried other methods, so I wouldn't know where to find the tools.
The Following User Says Thank You to TomBall For This Post:
Old 06-18-2017, 12:56:19 PM
akuna akuna is offline
I bet you never break a ring either.
Old 06-19-2017, 09:23:16 PM
Wayne Riedlinger Wayne Riedlinger is online now
Ive always done them wit strips of sheet metal too. Works good and dosent cost anything but my time.
Old 06-20-2017, 10:34:04 AM
JBoogie's Avatar
Images: 241
I need something mostly for installing rings on aluminum pistons. I want an expander, not to be fooling around with shim stock and stuff.
Ihc M 4 ring piston change to a 3 ring year Ray Cardoza Antique Gas Engine Discussion 1 12-08-2008 04:35:03 PM
Use an O-Ring for a Piston Ring? OldironJeff Antique Gas Engine Discussion 10 08-27-2007 10:00:52 PM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Antique Gas Engine Discussion 3 06-24-2007 01:50:53 AM
piston ring end gap Dan Wiese Steam Stationary Engines, Traction Engines, Steam Boats 3 06-04-2005 05:17:36 PM
Piston ring's Tony Holbrook Antique Engine Archives 2 07-18-1999 10:05:37 PM
