25 HP Induction motor
this thread has 22 replies and has been viewed 2524 times
Old 11-21-2014, 02:50:06 PM
JIMnWV JIMnWV is offline
eMail NOT Working
Default 25 HP Induction motor
Was searching some of the older threads but still like a baby in a topless bar....confused. Just removed this motor from its original mounting plate and was just curious if it could be used for anything through a conversion or just as is? Motor was still running fine until this morning when they pulled its plug.
Old 11-21-2014, 03:21:17 PM
eMail NOT Working
Default Re: 25 HP Induction motor
Picture of the motor itself
The Following User Says Thank You to JIMnWV For This Post:
Old 11-21-2014, 03:29:09 PM
grif grif is offline
Heck of a 3phase converter idler.
The Following User Says Thank You to grif For This Post:
Old 11-21-2014, 06:13:04 PM
John Newman, Jr.'s Avatar
568 Ft.Lbs of torque at 575 RPM!
Bet you could move a railroad bridge with something like that. Oh wait - It did. Pretty impressive for an 88 year old motor.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-21-2014, 09:31:54 PM
Joseph Joseph is offline
you could use it to built a phase converter or an induction generator
The Following User Says Thank You to Joseph For This Post:
Old 11-21-2014, 10:46:51 PM
steve mallette steve mallette is offline
If one had enough power...
The Following User Says Thank You to steve mallette For This Post:
Old 11-21-2014, 11:30:32 PM
make a great mooring for a pretty large boat.
The Following User Says Thank You to Ed Sparks For This Post:
Old 11-22-2014, 12:11:35 AM
I would look into doing a diesel powered induction generator. Should put out a pretty good wattage.
Now only if I was lucky enough to find something like that!
Robert
The Following User Says Thank You to Railroads For This Post:
Old 11-22-2014, 02:32:30 AM
armandh armandh is offline
if it is a variable speed it may be an unusual variety noted for full torque at low speed and they are reversing.
if it is fed AC power on the slip-rings and has a commutator with movable brushes that feed the stator it may be one of these "Schrage motors"
https://www.google.com/#sugexp=ernk_...w=1275&bih=708
if so it may not be useful as a traditional generator, but possibly an induction generator. [3 pole no 6 pole yes]
by setting the brushes to a speed [at 60 HZ] that is lower than the turning power by an amount greater than the induction slip.
Old 11-22-2014, 08:30:47 AM
eMail NOT Working
if so it will not be useful as a traditional generator, but possibly an induction generator.
Yes sir it is reversing and also variable speed. Not sure what is going to happen to it in the near future, not sure how our contract reads but normally we are to dispose of them. I personally would like to see it live on, I'm certain I heard one of the men say it was installed in 1929. This is a pic of the control for it that is now being used on a motor that was forgotten.... How do you do that? I guess because it was under a cobweb / dust covered bench. Appreciate everyone's knowledge of this.
Westinghouse 1.5 induction motor help (compressor motor) eeprete Generators & Electric Motors General Discussion 20 10-30-2014 04:41:22 PM
Repulsion-Induction motor jdunmyer Generators & Electric Motors General Discussion 7 02-10-2010 11:51:14 AM
1915 Induction Motor Fred Berry Generators & Electric Motors General Discussion 1 01-30-2010 03:23:16 PM
FairbanksMorse Induction Motor VicP Generators & Electric Motors General Discussion 1 07-15-2007 05:27:08 PM
GE Repulsion-Induction Motor Roger Smith Generators & Electric Motors General Discussion 11 10-02-2004 12:45:58 AM
