Hand starting a tractor-will it really hurt ya?
this thread has 10 replies and has been viewed 3381 times
Old 12-17-2005, 11:07:14 PM
Linda
Default Hand starting a tractor-will it really hurt ya?
Since I got my Farmall A a few week ago, I keep hearing "don't hand crank it, it will break your arm." Will it? Is there a proper technique. this will bother me until I try it, unless I here alot of "NO-DON'T" from you all. I think it would be quit pleasing..............
thanks Linda
Old 12-17-2005, 11:35:34 PM
sparkplug54 sparkplug54 is offline
Default Re: Hand starting a tractor-will it really hurt ya?
Linda, If you do try to start it with the hand crank DON'T rap your thumb around the crank. It could easily break your thumb. As for breaking arms I suppose it could do that to but never heard of anyone personally. Dan Sheldon
Old 12-18-2005, 12:11:57 AM
Kevin Roth Kevin Roth is offline
Linda, If you don't rap your thumb around the crank and don't try to turn the crank all the way around you should be OK. I told my boys to only pull up on the crank and never never push it down. If it backfires it will pull the crank out of your hand and not break your thumb or arm.
Kevin
Old 12-18-2005, 01:01:02 AM
How to properly hold a crank is important...........but not as important as having the magento adjusted to trip at slightly after top dead center.
Old 12-18-2005, 01:45:30 AM
John G. Simpson
if you hold the crank with fingers and no thumb,you should be fine. i have an a and a b with battery ignitions, both start better with the crank than with the starter. im not always bright and some times start them in gear and wait for it to roll by and then get on( not recommended), but great for races.
lotsa luck with your new toy
john
Old 12-18-2005, 07:31:03 AM
Linda: I have a friend who started a 10-20 titan with the magneto in the advanced position (he forgot to place it in the retard position) with his thumb around the handle. Well, it backfired and six weeks or so later after the cast was off his arm..... he straightned out the rather large "BENT" crank handle. Only pull up and dont wrap the thumb around the handle. Never try to "spin" the crank while trying to start a tractor engine. Nothing good can happen .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 12-19-2005, 12:13:33 PM
Tanner Remillard's Avatar
Images: 10
Ok, call me stupid, but I dont understand how wraping your thumb around the crank can break your thumb if it backfires. When it backfired, the crank would grab and push down on your hand on the other four fingers, not up on your thumb
Old 12-19-2005, 02:55:08 PM
Forrest A's Avatar
Exclamation Re: Hand starting a tractor-will it really hurt ya?
You want to not only keep your thumb on the same side that your fingers are and ONLY pull up! If you contiue around back to the down position you will place your head in line with the crank handle which if the engine either backfires or the crank doesn't release from the end of the ratchet will clobber you right into the Darwin awards.
Forrest A
Old 12-19-2005, 03:07:23 PM
Images: 10
Well I know your only supposed to pull up on it, but I still dont see how pulling up on it can break your thumb like everyone else says
Old 12-19-2005, 07:59:12 PM
Well Tanner think about it , your thumb is grasping the handle , the engine back fires with great force in a split second the handle is going to work its way between pointer finger and thumb. From the direction of the handle and the somewhat vulnerable thumb somethings gotta give. My opinion anyway. Dan S
Hiller Yard Hand Garden Tractor K.Watkins Garden Tractors / Mowers / Scooters 34 05-14-2014 12:20:37 PM
Sears Yard Hand tractor Jeff Conner Garden Tractors / Mowers / Scooters 3 12-03-2011 04:12:47 PM
Hiller Yard Hand Tractor info K.Watkins Small Air Cooled Gasoline Engines 4 04-16-2006 11:01:43 PM
Fairmont 4HP hand crank for starting Joyce Thomas Antique Engine Archives 1 09-15-2004 02:02:40 AM
Will electrolysis hurt the bore? Roland Antique Engine Archives 6 02-12-2001 01:24:22 AM
