Smokstak Down Under
Villiers Lightweight Engine Carb & Manifold
this thread has 36 replies and has been viewed 1578 times
Old 06-29-2018, 06:39:58 PM
Scotty 2 Scotty 2 is online now
Default Re: Villiers Lightweight Engine Carb & Manifold
Hello Ozzie
Is that a Mk 20 Villiers on it?
Cheers Scott
Old 06-29-2018, 07:02:37 PM
Clapper Clapper is offline
[QUOTE=Scotty 2;1494555]Hello Cobba.
Another thing I've noticed is the engine numbers for the Lightweight. They have different prefixes ie number before the X. I wonder if this signified where they went?
What's the engine number of your engine Ozzie? Have you by any chance looked at the date on the flywheel?
The Rover is earlier then the Southern Cross if the date on the flywheel is anything to go by.
Cheers Scott
Hi Scott
Villiers with an X in the engine number where made in Australia, no X made in the UK.
Ian
Old 06-29-2018, 11:36:05 PM
OzzieHawker OzzieHawker is offline
Photo Re: Villiers Lightweight Engine Carb & Manifold
Here it is.
ID:	313290   Click image for larger version
The Following User Says Thank You to OzzieHawker For This Post:
  #24
Old 06-30-2018, 12:22:24 AM
Originally Posted by Scotty 2 View Post
Hello Ozzie
Cheers Scott
Scott, engine is 422X = 25C I think??
  #25
Old 06-30-2018, 12:43:47 AM
Hello all
We might be onto something with the Villiers numbers.
Ozzie's is 2423X1672 for a Singer
Ours are 2427X for the Rover and the Southern Cross is 2429X9152.
Maybe the number before the X are for the mower maker?
I haven't found the number after the X for the Rover yet. It's not where the Singer and Southern Cross have theirs
Cheers Scott
Old 06-30-2018, 01:20:54 AM
Hello all
Cheers Scott
Yep could be on to something here - Scott, last number for Singer is 8 not 2, hard to see.
Old 06-30-2018, 02:36:21 AM
cobbadog cobbadog is offline
No doubt that late Ron Wiley would know exactly what belongs to what. His knowledge was right up there. I wonder if all his hard work and research has been saved?
  #28
Old 06-30-2018, 03:21:59 AM
voljon voljon is offline
engine number 422x is a mk25c and was supplied to owen cox
number 2423x was a off the shelf engine supplied to various buyers.a vs150cc engine with b12a carby and 60283 crankshaft
number 2427x the same as 2423 but with a 60282 crankshaft
number 2429x was a vs150cc engine supplied to Toowoomba foundry with a B972AU crankshaft,with special breather valve components fitted by customer and with ivory finish.
regards john
The Following 4 Users Say Thank You to voljon For This Post:
  #29
Old 06-30-2018, 04:05:39 AM
Good news, Poor Ozzie now has a carby & manifold, found it right at my door step, unreal - he had 4 carbs in version condition & 1 with the manifold & workings. Thanks to all involved it’s been quite interesting. I’ll will update on my progress with Singer down the tract. A set of handle bars & wheels will nearly complete it.
Cheers.
  #30
Old 06-30-2018, 05:21:42 PM
Hello all
John: what a legend. Thanks.
Woohoo. Ozzie has a carbi.
There's isn't a spare piston where you found the carbs is there?
Cheers Scott
Villiers Lightweight Engine Carby OzzieHawker Carburetors, Mixers, Fuel Pumps and fuel delivery 0 06-17-2018 07:15:16 AM
REO carb and intake manifold dllode Antique Autos and Trucks 7 04-07-2017 10:13:19 PM
22-36 manifold/carb Matt S Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 02-02-2014 04:38:16 PM
Cushman Model C - Schebler D Carb & Manifold jacksoldgasstuff Antique Gas Engine Discussion 2 06-11-2012 03:04:56 PM
Help ID Carb/Manifold/Governor Monkry Antique Gas Engine Discussion 0 04-03-2005 09:16:39 PM
