Smokstak Down Under
Villiers Lightweight Engine Carb & Manifold
this thread has 36 replies and has been viewed 1578 times
Old 07-01-2018, 12:01:31 AM
cobbadog cobbadog is offline
Default Re: Villiers Lightweight Engine Carb & Manifold
I wonder if he has it running yet?
Old 07-01-2018, 12:38:56 AM
OzzieHawker OzzieHawker is offline
Originally Posted by Scotty 2 View Post
Hello all
John: what a legend. Thanks.
Woohoo. Ozzie has a carbi.
There's isn't a spare piston where you found the carbs is there?
Cheers Scott
Scotty, no spare piston sorry he only had carbs. Will keep my eye out for a piston.
The Following User Says Thank You to OzzieHawker For This Post:
  #33
Old 10-20-2018, 10:56:03 PM
Photo Re: Villiers Lightweight Engine Carb & Manifold
Hi,
Update on singer lawn mower. Finally got engine back together & running very nicely. Next is to find some handlebars. Laugh about the pumper muffler if you must but it’s all I had to work with.😃
Cheers.
  #34
Old 10-21-2018, 06:25:14 PM
I have a pipe bender that could make your handle!
  #35
Old 10-21-2018, 08:32:37 PM
I’ll look around for some old bars I think cobber, something close that I can modify - any ideas? Maybe old rover ones might do it? I’m going to run a small pump of the pto if I can find one - need something vertical I’d say?
Cheers
Old 10-22-2018, 01:35:35 AM
Can't remember what style they would be. Some old push mowers might have a similar style being joined together near the top then splayed outwards or a modified Victa 18 handle.
With the pump idea you could hook up a reciprocating pump working the arm backwards and forwards off a cam.
  #37
Old 10-22-2018, 06:23:09 PM
Hello all
Cheers Scott
Scotty,
Did you find a piston? I haven’t come across anything yet, still looking though. Wouldn’t have a spare pull or windup starter floating about?
Cheers.
Villiers Lightweight Engine Carby OzzieHawker Carburetors, Mixers, Fuel Pumps and fuel delivery 0 06-17-2018 07:15:16 AM
REO carb and intake manifold dllode Antique Autos and Trucks 7 04-07-2017 10:13:19 PM
22-36 manifold/carb Matt S Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 02-02-2014 04:38:16 PM
Cushman Model C - Schebler D Carb & Manifold jacksoldgasstuff Antique Gas Engine Discussion 2 06-11-2012 03:04:56 PM
Help ID Carb/Manifold/Governor Monkry Antique Gas Engine Discussion 0 04-03-2005 09:16:39 PM
