Smokstak Down Under
Igniter Coil
this thread has 5 replies and has been viewed 577 times
Old 10-12-2018, 04:28:23 AM
KODon KODon is offline
Question Igniter Coil
Hi Everybody I am looking for information how to make a 6V coil to to go with a igniter engine or does any one know where I might buy one
Thank Ken
Old 10-12-2018, 04:59:47 AM
Famous Fitter Famous Fitter is offline
Default Re: Igniter coil
Hi Ken,
just use a Ballast out of an old Flouro light, they are easy to get and work a treat !!! Not exactly period correct , but still a low tension coil.
Cheers Justin
The Following 2 Users Say Thank You to Famous Fitter For This Post:
Old 10-12-2018, 10:25:15 AM
Geist Geist is offline
which wires do you use on the ballast?
Old 10-12-2018, 07:01:02 PM
DustyBar DustyBar is offline
The "old" style ballasts only had two wires. The fixtures had a push button start or a little starter in a can. Modern ballasts may have 8 or more wires. Those won't work for this application.
The Following User Says Thank You to DustyBar For This Post:
Old 10-12-2018, 08:30:37 PM
They sure do. Use the black and white wires.
Jim
Old 10-21-2018, 02:44:53 AM
Hi Justin Found and old style starter and it works well thanks for you help
Wico type FG single coil & F Double coil magnetos. Dennis Wyatt Magnetos, Ignition Coils and Spark Plugs 5 10-29-2012 05:58:55 PM
Nelson upright Wico FG single coil & F Double coil magnetos Dennis Wyatt Small Air Cooled Gasoline Engines 2 07-06-2011 08:34:21 AM
Engine igniter help what do you pefer - coil or mag? The motor kid pig guy Antique Gas Engine Discussion 19 07-18-2009 09:56:16 AM
Convert Igniter/Mag Engine to Plug/Coil/Battery? Plntdctr Antique Gas Engine Discussion 4 05-28-2009 07:38:10 PM
Interesting coil find: The Chief Super Ignition Coil packrat56 Antique Gas Engine Discussion 3 09-14-2007 09:16:19 AM
