Smokstak Down Under
7 HP New Way Twin Generator and Bracket
this thread has 1 replies and has been viewed 376 times
Old 10-30-2018, 03:31:20 AM
AussieIron AussieIron is offline
Default 7 HP New Way Twin Generator and Bracket
Looking for any info on the friction drive set up for the New Way branded, (Wizard R1), generator on my 7 HP. I have been able to make a bracket from photos and dimensions given to me by a fellow Smokstaker. I can get it to run with normal cone shaped friction drive. (see photos for mock set up). I was wondering if this is right as I have also seen a straight drive with no spring governor. Appreciate any info or photos of correct set up.
ID:	321813   Click image for larger version
ID:	321814   Click image for larger version
ID:	321815   Click image for larger version
The Following 2 Users Say Thank You to AussieIron For This Post:
Old 11-02-2018, 04:50:37 PM
Default Re: 7 HP New Way Twin Generator and Bracket
I'll just give this one bump then let it fade away.
HELP to Identify Magneto Bracket (no number on the bracket) MiqC2001 Magnetos, Ignition Coils and Spark Plugs 3 07-24-2018 10:07:24 AM
Bosch Magneto & Bracket -Twin City? OzzieHawker Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 10-05-2014 06:23:39 PM
New Way Twin Friction Mag Bracket. AussieIron Smokstak Down Under 0 07-01-2012 02:37:10 AM
New Way 7 HP twin Magneto bracket. AussieIron Smokstak Down Under 9 06-23-2012 07:00:49 AM
TLC generator bracket gambitace71 Small Air Cooled Gasoline Engines 0 03-15-2011 06:22:24 PM
