Smokstak Down Under
Clinton Outboard Motor
this thread has 24 replies and has been viewed 761 times
Old 11-08-2018, 08:41:11 PM
Scotty 2 Scotty 2 is offline
Default Re: Clinton outboard motor
Originally Posted by typak View Post
Generally the plain two stroke oils are just a clean burning SAE 30 oil, also quite suitable for two strokes with drip oilers where 30 is specified.
https://www.castrol.com/en_au/austra...garden-2t.html
So you recommend this modern 2 stroke oil with detergents to be used in engines such as the Sunshine and Petter 2 strokes?
Old 11-09-2018, 10:34:52 AM
bartlett0815 bartlett0815 is offline
I tried to attach the entire manual but the file is too large. Here are the scans for the first half of the manual.
Kevin in NC
The Following User Says Thank You to bartlett0815 For This Post:
Old 11-09-2018, 10:36:06 AM
The next 4.
Old 11-09-2018, 10:39:42 AM
And finally the back cover. In the manual I found a letter from my father seeking repair parts for the motor in June 1963 when I was 11 months old. I don't know how old the motor was at that time but it was definitely still in use in the late 60's/early 70's.
Best regards,
Kevin in NC
Old 11-09-2018, 02:04:57 PM
Exclamation Re: Clinton outboard motor
Second page of the owners manual posted by Bartlett0815 states and I quote "1/2 pint SAE 30 NON-Detergent oil to I gallon regular gas". That is a 16:1 mix (1 cup oil to 1 Gal gas). With todays alky adulterated gas, I would use high test. less alky, and better regulation of the amount put into the gas. My son has found up to 27% alky in regular - death to a 2 cycle engine, and destructive to neoprene parts (seals and fuel system componants)> I would not use modern lubricants. TCW-3 OIL should work OK. They didn't have alcholized regular gas back when this engine was built
Old 11-09-2018, 03:24:40 PM
Your a legend Kevin. Thank you.
Old 11-09-2018, 04:28:03 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: Clinton Outboard Motor
When I was a kid, I ran one of these on a small V-bottom boat. TC-3W is what we used in these, and I ran it for hundreds of hours with 24:1 ratio instead of 16:1.
Generally speaking, TC-3w is a 'two cycle 30 weight' spec. Most 'marine' two-cycle oils are designed to minimize oil fouling at the lower temperatures of a raw-water cooled outboard. The Clinton Air-Cooled ran higher combustion chamber temperatures than a typical outboard, and as a result, exhaust temps were pretty high, and that's one of the two primary reasons why they ran an impeller-pump in the drive- to keep the temperature of the drive leg from getting so high that it'd steam fog you every time you idled it down from high speed... but moreso, it made the engine a whole lot less noisy.
I never had a problem with TC-3W 2-stroke oil at 24:1... never stuck a ring or seized, never any damage or performance issues. After discussing it with several of my outboard mechanics, they noted that the 2-strokes were generally identified for 30wt were such because "for-purpose" 2 stroke oils didn't exist as they do today.
Given modern choices, I would probably pick STIHL Ultra, or some oher type identified for air-cooled 2-stroke oil over non-detergent 30wt.
Old 11-09-2018, 05:20:59 PM
Please don't call me a legend, it might make me a bit too proud of myself. But I must admit I sort of like the title. I think the real legend would be my father. He dropped out of high school in 1945 and joined the Merchant Marine, then did stints in both the Navy and Coast Guard. He continued his career in steam with DuPont for another 30+ years. One of the most intelligent men I ever knew. He could build or fix most anything. Both of my parents grew up dirt poor on farms during the great depression so they developed the lifelong habit of never throwing anything away that might be valuable for something. So Dad never threw away the Clinton engine manual years after the motor had been retired. I still have all his old marine engineering manuals from the 1940's, automotive repair manuals from the 50's, his slide rule and most of his hand tools. Dad's been gone since 1984. He is the legend.
Best regards,
Kevin in NC
The Following 2 Users Say Thank You to bartlett0815 For This Post:
Old 11-09-2018, 05:34:09 PM
So around we go. We're back to Cobba's post. Valvoline, which happens to be TCW3.
I like seeing smoke coming out the 2 strokes. An easy indication of oil there doing its job.
Yep. Your dad's definitely a legend Kevin but your still a legend for not throwing it all away. We all hear of this sort of stuff been thrown in the bin all the time.
Cheers Scott
Old 11-09-2018, 08:10:30 PM
ken dunlop ken dunlop is offline
Thanks Scott
I'll stick with the normal 2 stroke mix.
Cheers Ken
---------- Post added at 07:10:30 PM ---------- Previous post was at 06:52:51 PM ----------
Hi Kevin
At this stage I have no use for the motor and intend to sell it. I have had it going a few years ago and just wanted to have it running in case someone was interested in it. Thanks for the offer of the manual, but hopefully I won't be needing it, but will keep it in mind if the situation changes.
Cheers Ken.
Old Clinton Outboard Identification, Help please! Bread Antique Marine Engines and Outboard Motors 0 06-18-2017 10:06:21 PM
Clinton 300 outboard question motor12 Antique Marine Engines and Outboard Motors 0 10-01-2014 03:20:27 PM
3.5 horse clinton outboard terry ravenscraft Antique Marine Engines and Outboard Motors 0 05-30-2011 06:24:37 AM
Clinton K300 outboard bwdbrn1 Antique Marine Engines and Outboard Motors 5 07-25-2010 08:39:30 AM
clinton engines,outboard parts Daniel Lowe Antique Engine Archives 1 06-06-2001 09:33:57 PM
