Smokstak Down Under
Clinton Outboard Motor
this thread has 24 replies and has been viewed 763 times
Old 11-09-2018, 08:34:23 PM
Wayne Timms Wayne Timms is offline
Default Re: Clinton Outboard Motor
Hi,
I happen to have a brand new old stock tin of Castrol 2 stroke self mixing.
Going by the logo - late 1940s - early 1950s.
When you shake the tin, it sounds just as watery as the new stuff.
Regards,
Wayne
ID:	322486   Click image for larger version
The Following 3 Users Say Thank You to Wayne Timms For This Post:
Old 11-09-2018, 08:35:53 PM
ken dunlop ken dunlop is offline
Default Re: Clinton outboard motor
Hi Kevin in NC
I notice that you have up loaded some, or all of the manual. Unfortunately I am unable to open the pdf for some reason.
Thanks anyway.
Cheers Ken.
Old 11-09-2018, 09:09:25 PM
Scotty 2 Scotty 2 is offline
If your going to sell it, give Spiro a Cooee. He may know someone who wants one. Send a PM if you want to know how to contact him
Cheers Scott
Old 11-10-2018, 12:36:32 AM
rodneyt rodneyt is offline
Wayne: the Denmark group over here - WestOz, could 'use' that tin of oil,
it would be perfect for this 'new-in-the-box' Seagull.
how about that, they also have a Clinton!
cheers Rod.
ID:	322495   Click image for larger version
The Following User Says Thank You to rodneyt For This Post:
  #25
Old 11-10-2018, 09:12:00 PM
typak typak is offline
Originally Posted by Scotty 2 View Post
Quite a number of older 2 strokes use SAE 30 non detergent engine oil in the mix.
Cheers Scott
Why must non detergent oil be used in older 2 strokes Scotty? how does detergent and dispersant work in a 2 stroke engine as compared too 4 strokes?
and what ill affect do they have? does it make a difference having a pre mix solvent in a 30 or 40 weight 2 stroke oil when used in drip oiler lubrication and will be mixed with petrol through the crankcase induction cycle anyhow? thanks in advance for the answer for this complex and perplexing question.
Old Clinton Outboard Identification, Help please! Bread Antique Marine Engines and Outboard Motors 0 06-18-2017 10:06:21 PM
Clinton 300 outboard question motor12 Antique Marine Engines and Outboard Motors 0 10-01-2014 03:20:27 PM
3.5 horse clinton outboard terry ravenscraft Antique Marine Engines and Outboard Motors 0 05-30-2011 06:24:37 AM
Clinton K300 outboard bwdbrn1 Antique Marine Engines and Outboard Motors 5 07-25-2010 08:39:30 AM
clinton engines,outboard parts Daniel Lowe Antique Engine Archives 1 06-06-2001 09:33:57 PM
