Emergency stop switch kicks out when i push start switch
this thread has 9 replies and has been viewed 2865 times
Old 08-02-2012, 04:47:48 PM
hurdy hurdy is offline
Default Emergency stop switch kicks out when i push start switch
I Have a Genset Model # 15OMDL3-3CR/13487A Serial# B860796521 Engine L-317D-M. I have replaced circuit board , The mechanics want $125.00 an hour from time they leave shop which is 45 minutes away one way. Times are to hard now!!Anyhow Solenoids are good, power and grounds are good.I pretty good at fixin things but I don'to this everyday. I'd appreciate any help, Thanks Mike
Old 08-02-2012, 06:44:08 PM
Billy J Shafer's Avatar
Default Re: Emergency stop switch kicks out when i push start switch
Are you talking about the fault breaker. We can help you here.Just need more information.
Old 08-02-2012, 08:04:20 PM
The red emergency stop switch kicks when you push the start stop rocker switch s11 to start. the fault breaker reset breaker cb12, or the or the dc breaker cb13 kick off. It's just the emergency stop dc control breaker switch cb11
the fault beaker reset cb12 and dc breaker cb13 do not kick out ,It's only the emergency stop dc control breaker cb11 .Thanks Mike
Old 08-02-2012, 08:13:13 PM
kevink1955 kevink1955 is offline
Try disconnecting the temp and oil senders for the engine shutdown system, a grounded temp sender will trip the shutdown as soon as it goes to crank. The oil sender should be bypassed during cranking but disconnect it anyway to test.
Old 08-02-2012, 08:51:30 PM
THANKS KEVIN1955: i WILL TRY THAT FIRST THING IN MORNING, mIKE MY FINGERS ARE CROSSED
Old 08-02-2012, 10:03:42 PM
Please post an address. So someone can send you the service manual. If you don't already have one. It has all the test the socalled experts would charge you 125 an hour to do.
Also check over the wiring for cuts or shorts to ground. We can help you on this site and it is free. Well I might charge you a BEER.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 08-03-2012, 06:25:21 AM
e mail address is mhurdconst@aol.com,thanks for all help again.I'll check all possible places for wires to chafe,I disconnected hi temp sender wires and oil wires, problem still there.
Old 08-03-2012, 07:51:23 PM
http://www.cumminsonan.com/www/pdf/manuals/900-0184.pdf
The above link to the YD generator manual will likley be more helpful than the service manuals. I will send you a service manual as well.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 08-29-2012, 07:10:49 AM
Thanks for all that helped ,I have fixed the problem ,My problem was the fuel cut off solenoid inside the injector pump housing. The coil was bad, The new coil is more heavy duty and was told the original coils fail quiet often . It was a stanadyne model.
Old 08-29-2012, 07:50:51 AM
Glad you got the problem fixed. Thanks for posting what you found. It will help others in the future.
Onan 4.0CCK fuel pump prime using Stop side of Stop/Start switch? Magnetite Onan Generators 7 11-29-2011 10:31:10 AM
Onan 4.0 BFA 1R/16004c Start/Stop switch tdarden3k Onan Generators 2 07-04-2011 03:05:33 AM
2004 CMSD 10KW start/stop switch works intermittantly ERIC MEYERS Onan Generators 6 10-30-2009 07:11:39 AM
Start Stop Switch for Onan 25KW Nat Gas Genset Praetorian Onan Generators 3 10-23-2009 01:32:17 PM
Emergency Stop Switch 85KR elietz Onan Generators 1 01-25-2007 10:14:34 PM
