Onan MDJF stops released start switch Centrifugal Switch Problem
this thread has 10 replies and has been viewed 1354 times
Old 01-28-2015, 09:16:17 PM
Chuck711 Chuck711 is offline
Default Onan MDJF stops released start switch Centrifugal Switch Problem
Onan MDJF Diesel Generator stops when released start switch.
I jumped Centrifugal Switch wiring ( added on/off toggle )
and unit runs ok
What could my problem be ?
The plunger is good.
Chuck
Old 01-28-2015, 09:37:43 PM
Nazrat Nazrat is offline
Default Re: Onan MDJF stops released start switch Centrifugal Switch Problem
Sounds to me like you need to adjust the gap in the centrifugal switch. Disconnect it first as it is live with the engine off. Once it is disconnected, remove the wing nut and cover and you'll see the hex head on the adjuster under the contact.
-Tad
Old 01-28-2015, 09:53:08 PM
Tad
The contact are clean with gap.
Upon increasing RPM the contacts close as should then when start switch is released
the contacts open up and engine stops
Old 01-28-2015, 10:28:29 PM
See if the gap is at .020"
Old 01-29-2015, 12:46:34 AM
BigBlockChev's Avatar
Do you have a Hz setting on your Multimeter or better still a KIll a watt. If you do, see what the Hz is when it is shutting down, maybe your governor is set too high or the engine IS actually running too fast. Hz should be in the 60ish range for the engine to be turning around 1800 rpm. It is easy enough to adjust the locknuts on the front of the engine. They are just below the plate that the water pump is bolted to. Cheers Dan
The Following User Says Thank You to BigBlockChev For This Post:
Old 01-29-2015, 08:35:33 AM
Are the contacts "clean". They are like ignition points & must make good contact. Also check all connections from the switch back to the control box. On the J series sets I have seen, they all have spade connectors in line to the centrifugal switch and these are notorious for becoming brittle, cracking & not making contact.
Old 01-29-2015, 10:43:37 AM
Yes Contacts are good on Start Relay and Centrifugal Switch
Cannot understand why works well when I eliminate Centrifugal Switch using toggle switch
Old 01-29-2015, 12:41:54 PM
Because somewhere in the system, power is not making it from one side of the centrifugal switch back to the ignition / start disconnect relay.
If you are plugging your "jumper switch" into the spade connectors at the centrifugal switch to make it work, this only leaves one component out of the loop, the centrifugal switch.
Have you tried cleaning the contacts on the centrifugal switch with fine sand paper?
Old 01-29-2015, 01:01:46 PM
Kpack
I had to hold mine shut once with a broom handle to get it to hold on my jc. I don't know why they won't hold sometimes. Yours my be different from mine. In the picture out of my manual it tells in a emergency you can short it
Old 01-29-2015, 03:14:36 PM
I "think" this is what he is doing with the toggle switch.
onan 4.0 bf dies when start switch released need advise YellowLister Onan Generators 19 11-02-2014 10:04:51 PM
Onan 4k start/stop light doesnt work and stops running when release start switch JoshD Onan Generators 12 09-06-2014 07:51:40 AM
Onan 6.5 nhe starts but stops when switch is released Max Thompson Onan Generators 17 01-30-2013 01:15:26 PM
Onan 6.5NH 3CR/16004P Won't stay running after the start switch is released. Hudson69 Onan Generators 6 07-18-2012 06:17:03 PM
Onan stops when I let off the start switch shadetree13 Onan Generators 15 10-21-2011 06:56:52 PM
