BGA wiring questions, remote switch wires identification, bad rocker switch?
this thread has 5 replies and has been viewed 658 times
Old 06-29-2015, 08:34:49 PM
shadow44 shadow44 is offline
Question BGA wiring questions, remote switch wires identification, bad rocker switch?
I have finally started on my BGA install for my house. I got it converted from 120v to 240v today.
I got this from a guy that ripped it out of hos RV before scrapping it. he just cut the wires.
I have 4 wires coming out of the control box. red, green blue brown
Blue is power for the fuel pump.
the others are???
I cant get it to shut off with the rocker switch on the control panel. Starts ok, but I have to disconnect the battery to get it to shut down. Everything in the control box looks un-molested. what should I test
Old 06-29-2015, 08:41:59 PM
BigBlockChev's Avatar
Default Re: BGA wiring questions, remote switch wires identification, bad rocker switch?
Please post the full serial and model # or your unit as well as an email address so manuals and wiring diagrams can be sent to you. A couple of pics of the gen where the wires have been cut would probably help too. Lots of guys here willing to help but we need a bit more info to zero in. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 06-29-2015, 08:42:02 PM
Kpack
Give us the full model and serial number and a email and we'll get the wiring diagram and service manual to you. The experts will be along to help you. Don't let those wires touch each other or you till you get it figured out . You don't want a shocking experience or let the magic smoke out of your gen.
Old 06-30-2015, 07:35:33 AM
Originally Posted by shadow44 View Post
Starts ok, but I have to disconnect the battery to get it to shut down. :
Those rocker switches are a weak point in the control system. Just a mechanical momentary contact switch. You could try some contact cleaner & work it back & forth several times. I have been replacing them with part #VLD2S00B-AZCOO-000 rocker switch from Allied Electronics, $6.95.
http://www.alliedelec.com/search/res...FYQ-aQodOXIN_g
Old 06-30-2015, 09:58:41 AM
jkellis3 jkellis3 is offline
Is there a way to test the switch for proper operation? I am using a fluke on the 3 pins and do not get continuity between any of them when holding it on or off. I am questioning this on my own generator troubleshooting.
Thanks.
Old 06-30-2015, 02:14:58 PM
nothingbutdarts nothingbutdarts is online now
Thanks.
It sounds bad to me! The center terminal should be commom to both other terminals depending on which way you have the switch depressed.
The Following User Says Thank You to nothingbutdarts For This Post:
Kohler Generator 7.5 remote start switch wiring DougHess Kohler Generators 13 12-05-2014 12:03:23 AM
Need help on connecting motor wires to switch on saw. Delta 34-580 Windmill Bob Generators & Electric Motors General Discussion 2 11-08-2013 10:16:39 PM
Rocker switch question Doogdoog Generators & Electric Motors General Discussion 7 05-15-2013 08:42:22 PM
Wiring remote start from transfer switch CEB5 Onan Generators 5 07-04-2009 12:08:58 PM
Rocker switch wiring Farquhar Onan Generators 2 08-14-2007 08:35:25 AM
