this thread has 4895 replies and has been viewed 323052 times
Old 10-09-2014, 09:49:04 PM
Jim McIntyre's Avatar
Default Re: What have you done to your Onan generator today?
Originally Posted by JohnnyC View Post
...Within short time my 15.0JC will find a deep dark corner in my garage where it will "sleep", posting here will become far and few for me...
Until your JC breaks, at which time you'll be back. And if this was all in one thread, you could just revive that thread with your newfound issue, and it'd be easy for all of us to see what transpired...
Just sayin' (to quote one of our resident smart guys...)
At any rate, I think we're all happy you popped in to post about your set!
Old 10-09-2014, 09:49:23 PM
len k len k is online now
IF it were a pipe the flow restriction would not have any effect on temp rise of the metal skin. The glass packing might have some little insulating valve though. Still not hard to add a radient heat sheild.
Testing should be done at full load. At full load my 7NHM burns 3.25 times what it does no load. RPM is same 1800 so that means all that extra BTUs of fuel energy is going into heat, likely a higher temp exhaust. At best (full load) only ~ 18.5% of fuel energy going into a 15JC comes out as power the rest comes out as heat.
Old 10-09-2014, 09:56:31 PM
JohnnyC JohnnyC is offline
Len, I think you are right about the fiber glass packing around the cherry bomb's perimeter offering some insulating valve. I am really itching to test it using my infrared thermometer. It is 10 PM on the east coast. I wonder if I'd piss off the neighbors if I fire up the 15.0JC for 30 minutes with the glass pack cherry bomb while testing?
JohnnyC
New Jersey
Old 10-09-2014, 10:12:03 PM
The pressure pulses will force some hot exhaust into the fiberglass, and a little may reach the metal skin to warm it.
Depends on how you feel about your neighbors, my GF wants me to buy a 10ft dinosour to stare at a bum neighbor that is dumping all his leaves and stuff on my property.
Old 10-09-2014, 10:20:50 PM
Power Power is offline
I would be interested in noise level with that muffler.
If close to OEM in noise, it is a nice looking replacement.
Looks a lot better than automotive or tractor mufflers people have been using.
Old 10-09-2014, 11:06:49 PM
Power, I wish there was a way I could measure the noise level. Is there an App that is available for our smartphones? I will check it out in the morning. If so, I can take a reading and publish it and maybe someone else with a similar setup can do the same.
I think my OEM muffler is all rotted out on the inside. When I shake it, it sounds like a baby rattle, but nothing falls out. Before I permanently clamped the cherry bomb to my JC, I hooked up the original muffler and to be honest, there was not much of a difference. I'm sure if my OEM muffler was new, it would be a different story.
The cherry bomb's outer shell is much thicker than an ordinary muffler. I would say the outer shell of the cherry bomb is almost as thick as the monster OEM muffler.
The cost for cherry bombs are under $40. I believe the OEM monster industrial mufflers are well over $100, but I really did not check.
JohnnyC
New Jersey
Old 10-10-2014, 01:41:03 AM
Quite mufflers is a science. Art of matching engine rpm , displacement,number of cylinders and muffler chamber size, and number of chambers. Problem is I think muffler manufacturer's don't publish any info on muffler details and general sizing guidlines, so I think it wanders into a black art guessing game for us.
Old 10-10-2014, 09:06:45 AM
Ted_Cool Ted_Cool is offline
I definitely would not apply any load to the engine before you install the demand regulator and adjust the mixture and timing.
Getting those wrong could burn a valve or melt a piston.
I like to use a vacuum gauge to get both adjusted well. There's a flat on the bottom of the intake manifold that is perfect to add a port.
Did you pull apart the distributor and make sure the advance mechanism was clean and healthy?
Old 10-10-2014, 10:04:14 AM
andylphoto andylphoto is offline
Two things I did not to, but for my Onan today...first, picked up the 1000-gallon tank I bought and had it installed, along with running the gas line to the shed for the generator.
Then, I built a panel with meters. Someone on here had done something similar with LCD meters from ebay. I forget who it was, but it was a great idea! I bought three meters--one is a frequency meter, while the other two show both voltage and current. Here is a link for the ebay auction for the voltage/current meters.
The generator itself hasn't been run yet--still finishing up basic maintenance & tune-up work before trying to start it.
ID:	208174   Click image for larger version
Old 10-10-2014, 11:15:52 AM
Right on and because I don't have the demand regulator hooked up I did not run a load of more than 9 amps. If time permits I can rig up the demand regulator temporarily. Using the bbq grill regulator I am manually regulating the flow demand by adjusting the tank's valve to make the set run smooth for the load I am running.
---------- Post added at 11:15 AM ---------- Previous post was at 11:12 AM ----------
How much does it cost to fill a 1000 gallon propane tank? One of the things I want to build is a complete panel of meters to monitor and ensure all is running. I am very interested in the design and recommended meters others here used.
JohnnyC
New Jersey
