LP to NG: What is required?
this thread has 10 replies and has been viewed 800 times
Old 10-10-2017, 11:39:00 AM
JT240Z JT240Z is offline
Default LP to NG: What is required?
I currently have a JC genset that has the "tri-fuel" option. I know it will run on gasoline and it was originally set up for either LP or NG. Not sure yet. Exactly what would be required to change from LP to NG or from NG to LP? If it matters, it already has a demand regulator that feeds the carb through a relatively large diameter hose.
Old 10-10-2017, 12:12:56 PM
Mac Sine Mac Sine is offline
Default Re: LP to NG: What is required?
For LP (propane) fuel you will need a primary regulator upstream of the demand regulator, feeding a positive pressure not to exceed the maximum inlet pressure value that us stamped on the body of the demand regulator.
For natural gas fuel you may or may not need a primary regulator upstream of the demand regulator, depending on the pressure of the natural gas supply.
A slight adjustment of the carburetor main jet load screw will be needed to trim between propane and natural gas, because of the difference in the heat content between the two fuels.
Optimum spark timing is also different between propane and natural gas. The unit-specific instruction book will provide these values.
The Following User Says Thank You to Mac Sine For This Post:
Old 10-10-2017, 01:01:54 PM
I've checked the operators manual (967-0120) and found nothing about carburetor adjustments between fuel sources. The references that I have seen are to making sure that both gaseous and liquid fuels not being turned on at the same time.
Old 10-10-2017, 06:54:13 PM
Max Thompson Max Thompson is offline
Timing and spark plug gap is the same for both gaseous fuels. It should start on either one with no adjustments. As mentioned above, you may have to make some minor carb adjustments after you get it running, you will need a way to load the generator and measure the frequency (Hz.) and voltage in order to get all carb and governor adjustments correct.
Many of us use a "Kill-a-watt" meter to measure frequency. They are around $20 at the box store or on-line.
The Following User Says Thank You to Max Thompson For This Post:
Old 10-10-2017, 07:56:46 PM
Plan on doing a complete load test and adjust once I get her fired up.
Already have one of these and a Fluke 177 meter to do the job:
http://www.homedepot.com/p/Klein-Too...L310/207144577
Old 10-18-2017, 12:46:17 PM
I keep hearing of the "slight adjustment" that's needed at the carburetor to go between LP and NG. Can someone give me an idea of how that adjustment would be made or point me in the right direction on any documents that would explain it? Looking for something a little more detailed than "turn the screw".
Old 10-18-2017, 04:50:35 PM
Billy J Shafer's Avatar
That is all there is to it. Turn the large mixture screw until it runs smooth. There is a adjustment rig you can buy. Set you back about 500.00 dollars.
Old 10-18-2017, 06:18:49 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
Also check and recheck for reliable starting, it is a balance between regulator setting and fuel mixture adjustment at full load to get it to start reliably and run good at full load.
Usually very easy, lots of wiggle room.
Old 10-18-2017, 08:44:10 PM
Jim McIntyre's Avatar
Originally Posted by JT240Z View Post
... Looking for something a little more detailed than "turn the screw"....
What I do is load the set to near 100% and monitor the frequency. Then adjust the main mixture screw for max frequency or ever-so-slightly richer than max. If you can't fully load the set, you can't properly set the mixture, as far as I'm concerned. You can get close, but the final setting ought to be under full load.
After that, remove the load and fiddle with the 'idle' screw until you get pissed off that it doesn't do much. Then repeat the above step.
From what I've read and understood, one does NOT adjust the regulator this way. The regulator is basically adjusted to be as close to 0 psi as possible without leaking gas. If you have a new-ish Garretson KN, just don't dick with it. It's probably fine and you can easily do more harm than good.
The Following 2 Users Say Thank You to Jim McIntyre For This Post:
Old 10-18-2017, 10:40:49 PM
JohnnyC JohnnyC is offline
To specifically answer your question, please refer to the arrow in the picture below ( a picture is worth a thousand words).
If the carburetor was already set for PROPANE, you may need to rotate the screw counter clockwise to allow more vapor. Fine tune as needed. 1/4 turn can have dramatic results / changes in the engine's performance.
JohnnyC
New Jersey
PTO Generator help required speedbuff Onan Generators 13 05-22-2016 07:34:23 PM
IHC Pig engine Mag required Norm Johnston Smokstak Down Under 17 06-08-2015 07:42:54 PM
4.5 New Way some assembly required Walt Roys Antique Engine Photos 0 06-11-2012 11:23:31 AM
CCK Information required island doug Onan Generators 7 04-22-2010 11:44:19 AM
Engine ID Required BobSaunders Scale Model Engineering 11 09-24-2009 09:10:01 AM
