Onan 7.5JB - Wiring
this thread has 75 replies and has been viewed 2641 times
Old 01-07-2017, 05:13:55 PM
kiteoregon kiteoregon is offline
Default Onan 7.5JB - Wiring
So the PO on this unit tried to label the lines, but the labels are since gone. Some of the wires are tied together, here are the pairs:
L1 = T1 & T6
L2 = T8 & T10
Then T9 & T11 are tied together as well as T3 &T5
I want to wire to a 220 circuit.
So, which of the T9 or T3 pair would be equivalent to the common? For the ground i assume i would just connect the ground to the ground post in the electrical box.
KO
Old 01-07-2017, 06:02:07 PM
Default Re: Onan 7.5JB - Wiring
900-0814 is the Yd gen-end manual you want. It has "re-connection" diagrams in it and an explanation about the neutral connection. This manual can be downloaded from the below linked site, thanks to Doug & Mike's hard work.
I assume this is the same JB you just had a fight with the points on, but without posting the model & serial numbers again we have to go back to your old thread to see if we can find that info. The data plate info will also let us find the build sheet & wiring diagram for your specific set.
http://www.twinslan.net/~n0nas/manuals/onan/
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 01-07-2017, 06:39:36 PM
I will look this up...
7.5 Jb - Serial: A960597423 Spec: 68774E.
I could not find the one you referenced, is this the correct one: 0900-0186 Onan Mobile, RV & AUX Genset Wiring Diagrams (06-1989).pdf
Old 01-07-2017, 07:50:43 PM
Sorry, should have read #900-0184 . I will look up your build sheet & print.
Your print should be attached, it includes reconnection diagrams. Did not find the build sheet, maybe Kevin or MBB can locate it.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 01-07-2017, 09:13:15 PM
So now how do i read this schematic? This is to be wired into a DPDT breaker, so 1 phase, 220, 60 Hz. But from this i am not sure how to figure out what T wires are tied together to create a hot leg?
L0 = T2, T7, T4, T12, these are all connected to the post in the wiring box, this should be my common. Should i connect the ground to the common, or to the ground post on the back of the generator that the battery uses?
Old 01-07-2017, 09:42:36 PM
MBB MBB is offline
Here is the build sheet. I cant read the AC wiring diagram number.
Here is the heater diagram.
The Following 4 Users Say Thank You to MBB For This Post:
Old 01-07-2017, 10:18:37 PM
Billy J Shafer's Avatar
It is wired for 120/240 single phase
2-4-7-12 is the common
The ground can go anywhere.
The Following 3 Users Say Thank You to Billy J Shafer For This Post:
Old 01-08-2017, 10:54:17 AM
MBB MBB is offline
It looks like I didnt include the complete control wiring diagram. Here are all 3 pages.
Old 01-08-2017, 11:56:29 AM
Jim McIntyre's Avatar
IF you are using this to tie to a building's power system, the T2, T7, T4, T12 is NOT ground. It is neutral.
Old 01-08-2017, 12:09:42 PM
Yes ground and neutral are two different items.
Onan 5.0 CCK wiring help Handyhiker1 Onan Generators 16 08-26-2015 07:12:49 AM
Onan wiring help on 2.5 AJ PecosPhil Onan Generators 5 07-29-2013 10:05:45 PM
Onan 4.0 Gen set wiring help Bwill Onan Generators 5 08-13-2011 07:41:25 PM
Hot Wiring a 4 CCK Onan c east Onan Generators 3 04-11-2011 08:17:58 PM
Onan CCK wiring sam c Onan Generators 2 06-23-2008 01:33:06 PM
