Onan 7.5JB - Wiring
this thread has 75 replies and has been viewed 2632 times
Old 01-29-2017, 08:11:33 PM
Ray Lynch Ray Lynch is offline
Default Re: Onan 7.5JB - Wiring
Kiteoregon
Do you have the JB manual for your set? From your posts, it seems you would benefit from reading it thru to get info such as setting the governor, etc that you need. It will help you understand better the overall operation of your set.
Check your meter against a known 230 volt source and if ok re-check the readings on your set.
Ray
The Following 3 Users Say Thank You to Ray Lynch For This Post:
Old 01-29-2017, 09:29:27 PM
kiteoregon kiteoregon is offline
So i verified that my MM is not moving a decimal point. So i have it connected to L1 and only able to get 2.20 - 2.40 volts. I would expect that L1 with my configuration should be putting out close to 110v. Additional ideas?
---------- Post added at 05:14:52 PM ---------- Previous post was at 05:04:51 PM ----------
I read through the service manual, the screw that i was adjusting was the governor screw. How far up is it safe to turn? As i turn the screw the RPMs go up as does the voltage, but i am just not sure how far it should go. Seems like a long jump 2.40 to 110?
---------- Post added at 05:29:27 PM ---------- Previous post was at 05:14:52 PM ----------
I started the gen and let it warm up, then twisted the governor screw to max, at max i was getting 5.xx volts. Seems like there is something else, i am off by a significant magnitude.
Old 01-29-2017, 10:30:49 PM
Augie1 Augie1 is offline
It is on the front of the
generator upper left side of the flywheel. I wouldn't mess with it just yet. It will be one more thing to get adjusted later. Do some more reading on this site about adjustments or in your manual. Have you looked inside the control box for a mouse nest? Have you checked out your voltage regulator board .
---------- Post added at 08:06:59 PM ---------- Previous post was at 07:59:24 PM ----------
If you turned the gov adjust to max you will be running well, well over the rated 1800 RPM. You don't want to ruin a good engine. Check all fuses and the VR board.
---------- Post added at 08:17:51 PM ---------- Previous post was at 08:06:59 PM ----------
Check out this thread by Jim on how To: Quick Test for the JB JC YD Voltage Regulator.
---------- Post added at 08:30:49 PM ---------- Previous post was at 08:17:51 PM ----------
https://www.smokstak.com/forum/showthread.php?t=146239
Old 01-30-2017, 08:14:52 AM
As mentioned above, you will not get from 3 volts to 240 with engine speed. You need to do some reading of the YD generator manual.
How long had it been since the generator was producing power. Built in 1996, you will have a voltage regulator board that may be the problem, or the gen-end may need to be flashed.
If you do not have the generator output wires configured correctly, you will not get proper voltage & may smoke something. Double check this configuration FIRST.
The Following 2 Users Say Thank You to Max Thompson For This Post:
  #25
Old 01-30-2017, 12:09:49 PM
I will pick up the parts today to make a test light and test the voltage regulator per the post / link above and report back.
I would expect that since i am only testing voltage on L1, i should expect to see 110, correct? Then once i get 110 on L1, check L2, i should also get 110 there. But first, will test the penthouse electronics.
Last run is unknown. The generator odometer has 115 hours, don't know much more of then history then that. The points were in very bad shape and took some time to clean just to get started, so it's probably been several years at a minimum. PO told me that it operated fine, just ran out of propane one day and so he disconnected the wiring and connect to a portable, then just never hooked it back up to the house.
Thanks.
Old 01-30-2017, 04:17:11 PM
Radarman Radarman is offline
KiteOregon, I am just down the road from you in Beaverton. Im no expert, but if you need a second set of eyes and/or tools, let me know. I just finished going through a JB last year so its not my first rodeo..
As far as why your voltage is reading low, as mentioned before it is most likely NOT related to RPM, but due to your voltage regulator, wiring or something like that.
The Following User Says Thank You to Radarman For This Post:
  #27
Old 01-30-2017, 04:34:16 PM
len k len k is offline
Might be easier to do a functional test on gen head (windings and rectifier diode)....
I don't know 3 phase units that well , but on my single phase JB with YD reg (electronic one) the field that reg feeds is ~ 12 ohms. If I disconnect the reg and apply 12 VDC to the field I get 140 VAC output out the 120 leads on mine. Polarity does matter, there is supposed to be a small flashing permanent magnet in the field that gives ~ 15-20 VAC output with NO reg connected.
To determine correct polarity on mine:
-- I disconnected the reg , ran gen and measured output voltage.
-- Then applied one alkaline 1.5 V D dry cell (flashlight bat) to the field , ran engine and measured output voltage.
-- Then reverse cell connections to field and repeated above.
The correct polarity is that which results in a higher output voltage.( the fields from magnet and electromagnet combine). If you have reg output connected in reverse I theorize output voltage that powers the reg will go near zero as it trys to bootstrap itself and reg will stall out from lack of voltage.
Old 01-30-2017, 06:10:15 PM
squidtrap squidtrap is offline
First thing i recommend is read the owners manual and operators manual that they sent, also buy a kill-a-watt meter for 20.00 (best 20 u will spend owning a generator) this way you get familiar with the gen, and will have the meter so when making adjustments you will see what is doing what.
You will be surprised how easy they are to work on once you get familiar with what does what. one wrong move and you could let out the magic smoke, and you do not want to do that.
Trust me that paperwork is your best friend, next to the experts here that will be guiding you through some of the issues you may come across, good luck, Ed.
The Following User Says Thank You to squidtrap For This Post:
  #29
Old 01-30-2017, 10:38:44 PM
Make sure your voltmeter is connected between the L1, L2, L0 connections and not between L1 , L2 and frame.
Because if you haven't made a connection between your neutral and the frame, then only stray capacitance will complete the voltmeter circuit and meter will read low.
Also if meter is bad/intermittent , could try a good light bulb between L1 and L0 ....... and between L2 and L0. See if it lights.
Sounds like your gen is wired in 120/240 double delta mode, the neutral L0 is typically the lead group T2, T4, T7, T12. and is connected to frame ( ground) for typical USA 120/240 single phase home utility power.
The Following 2 Users Say Thank You to len k For This Post:
  #30
Old 01-31-2017, 12:52:37 AM
Per Jim's post i removed the penthouse and tested with a 60w incandescent light bulb. After some pot adjustments the light bulb will come to full brightness. So at this point we can rule out the voltage regulator and transformers located in the penthouse.
I did find lots of mouse mess inside the electrical box under the penthouse however and cleaned that all up. The rest of the wires and housings in the box seem to be in good shape.
I am guessing now start to look at the generation side of things?
---------- Post added at 08:52:37 PM ---------- Previous post was at 08:51:04 PM ----------
Len, just saw your post, i will test with a light to verify it's not my cheap MM.
Onan 5.0 CCK wiring help Handyhiker1 Onan Generators 16 08-26-2015 07:12:49 AM
Onan wiring help on 2.5 AJ PecosPhil Onan Generators 5 07-29-2013 10:05:45 PM
Onan 4.0 Gen set wiring help Bwill Onan Generators 5 08-13-2011 07:41:25 PM
Hot Wiring a 4 CCK Onan c east Onan Generators 3 04-11-2011 08:17:58 PM
Onan CCK wiring sam c Onan Generators 2 06-23-2008 01:33:06 PM
