Onan 45EM Project
this thread has 30 replies and has been viewed 1332 times
Old 02-09-2017, 06:24:30 PM
Kyle K Kyle K is offline
Default Onan 45EM Project
Well another Craigslist find. I am now the owner of a 45 EM. By all means its mostly a toy as I know it has a healthy fuel appetite. After cleaning the mud wasp nest out of gas valve it came back to life and made voltage. Hour meter says 1073. Looks like someone was in head recently. Any do's or don'ts? Is 6 gallons a hour consumption a accurate fuel number?
Thanks Kyle
Old 02-09-2017, 06:53:16 PM
Default Re: Onan 45EM project
Originally Posted by Kyle K View Post
Is 6 gallons a hour consumption a accurate fuel number? Thanks Kyle
I would guess that is pretty close for full load consumption.
The Following User Says Thank You to Max Thompson For This Post:
Old 02-09-2017, 11:04:27 PM
Utah Onan Utah Onan is offline
I'm not sure about gasoline consumption.
But from the T-015 Gaseous Fuels guide it says that a 45.0EM uses 690 CFH of Natural Gas & 290 CFH of LPG. Hope that helps some. You've got an awesome set there with that 45.0EM.
- Utah
The Following User Says Thank You to Utah Onan For This Post:
Old 02-09-2017, 11:36:34 PM
Vanman Vanman is offline
690 CF/Hr natural gas is roughly 690,000 BTU/Hr.
Gasoline is around 115,000 BTU per Gallon, so
That math works out to 6 gallons of gasoline / hr.
The Following 2 Users Say Thank You to Vanman For This Post:
Old 02-09-2017, 11:38:56 PM
Troll's Avatar
Troll Troll is offline
Just about what my 45kva "EF" set uses at full load.
The Following User Says Thank You to Troll For This Post:
Old 02-10-2017, 12:49:09 AM
Troll's Avatar
As a side note: Retard engine timing about 4 degrees when using gasoline as opposed to gaseous fuels. Backfiring through carburetor is usually the result upon engine starting is usually the result if timing is not retarded.
Old 02-12-2017, 10:23:08 AM
Thanks for replies all. I would not go to gasoline but keep it on propane. To clarify my question a bit I found the 6 gallons on a google search how does that relate to propane. I have a all electric house which I have a 15 JC on right now to run partial load if need be. Its fed from a 250 gallon tank. If I really got in a long outage the 45 EM would handle the whole load. Do I have enough tank for even a short term run? In other words run the 45EM for a few hours to warm everything back up.
Old 02-12-2017, 10:38:31 AM
45 EM will burn 290 CFH of propane at "Full Load" which equates to 8.6 Gallons per hr.
Though the 45 KW set would likely not be running at full load very often, so your consumption could be more like 1/2 - 2/3 of that amount. Still a bunch of fuel.
I would not get rid of the JC.
Old 02-12-2017, 10:47:51 AM
Billy J Shafer's Avatar
The 45 does love fuel.
Old 02-12-2017, 11:08:49 AM
I keep having a mental picture of the 45EM starting and that tank freezing up like a Popsicle.
Onan cooling fan 45em bikehead Onan Generators 24 09-08-2017 02:30:35 PM
ONAN 45EM-15R bad boards? mefroe1 Onan Generators 15 01-26-2016 03:18:50 PM
Onan 45em generator Gregcrankshaft Onan Generators 50 08-19-2015 06:08:05 PM
Onan 45em won't start Nail banger Onan Generators 13 02-10-2015 05:26:51 AM
Radiator for Onan 45EM Dave Hammen Onan Generators 5 01-11-2008 10:58:44 AM
