Questions on Onan 30EC Generator with Ford 6 Cylinder Engine
this thread has 32 replies and has been viewed 1363 times
Old 09-21-2017, 03:15:07 PM
Billy J Shafer's Avatar
Default Re: Questions on Onan 30EC generator with Ford 6 cylinder engine
Originally Posted by grif View Post
Billy,,,, did Onan use a Colman or Dyna-Master electronic gov? Only reason I'm asking, for some reason in my Onan files I've got some docs for the Dyna-Master, likely during my chase on an EK30
Barber Colman was the company name. Dyna-Master is the name of the control system. Onan also used Woodward. There is another company GOA. Governors Of America. Good company just doesn't have a good dealer network. The last time I checked.
Old 09-21-2017, 03:29:07 PM
oldjohndeere oldjohndeere is offline
I just checked the unit and it is Barber-Coleman.
Old 09-21-2017, 04:08:36 PM
Ok we need the model number of the controller. I have the spec sheets but need the numbers.
Old 09-21-2017, 04:59:48 PM
The model number must be on the backside and I will have to cut the screws out they are so rusted. I will do that tomorrow if I get a chance. Thanks for all the information.
Old 09-21-2017, 05:14:41 PM
Does it look like this one.
Old 09-21-2017, 06:33:34 PM
No, its not that modern looking. Its just a plain rectangular box about 4 x 5 or 5 x 6 inches. On the face showing it has the wiring diagram and 2 small dials. One dial says gain and the other speed. Not totally sure on that second one till I look again.
Old 09-22-2017, 09:48:26 AM
Post Re: Questions on Onan 30EC generator with Ford 6 cylinder engine
Part Number is unreadable.
https://www.smokstak.com/forum/attac...1&d=1506087158
Old 09-22-2017, 11:22:02 AM
That's basically the same one as Billy showed you, his had a terminal strip and yours uses a pigtail.
Try Governor Controls
http://www.govconsys.com/#gsc.tab=0
If that is too rich for your blood you can try to find something chineseium on Ebay or Alibaba or something.
The Following 2 Users Say Thank You to pegasuspinto For This Post:
Old 09-22-2017, 11:33:24 AM
That would be the early version of this one
ID:	291882   Click image for larger version
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 09-22-2017, 01:58:18 PM
A quick internet search found this controller at www.partsfortechs, ESC 2301-a, on sale for $199.00. Can someone pull it up and tell me if it will work. It sounds to me like it will.
Onan 10 kw Generator w/Ford 8nnn Engine Gramps Multi-Cylinder Stationary Engines and Power Units 1 03-08-2017 01:36:51 AM
Just bought an Onan generator with a Ford engine cmrobins Onan Generators 22 11-26-2014 11:42:24 AM
Onan generator (1964 30ec) jethro Onan Generators 2 04-10-2012 07:24:14 AM
Onan 30EC with Ford need manuals 7mpoole Onan Generators 5 01-04-2012 07:53:22 PM
Onan Generator w Ford 4 cyc engine Tim_Ball Onan Generators 10 11-16-2007 07:21:15 PM
