New Proud Owner of an Onan JC
this thread has 81 replies and has been viewed 2842 times
Old 10-04-2017, 01:54:47 PM
stretch67 stretch67 is offline
Default Re: New proud owner of a JC
New to me 2014 Chevy Silverado
Dexos 0W20 8.5 Quarts
Full Synthetic
So that has to say something about the new oils
Old 10-05-2017, 11:39:39 AM
John Newman, Jr.'s Avatar
Leon:
One side of that diaphragm has never seen anything but air. Could be weakened from being constantly flexed while dry all its life. Maybe not, but I'd at least check it before putting gasoline to it.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 10-05-2017, 11:57:50 AM
len k len k is offline
Even wet fuel pumps can crack the diaphragm. Had a 85 Chevy 305, oil was thin, diaphragm was leaking.
Old 10-05-2017, 12:09:40 PM
It took me a long time to finally realize how a mechanical diaphragm fuel pump works. When it is dry, the diaphragm flexes a lot more than when the pump is actually filled with fuel and has built up pressure.
Old 10-05-2017, 01:08:59 PM
Leon N. Leon N. is offline
Things would have to get real bad around here for me to even consider using gasoline. Good comments. Lets hope I never have to resort to gasoline.
Old 10-09-2017, 10:48:03 AM
JT240Z JT240Z is offline
Good comments indeed. I'll be taking it all in and appreciate the extensive knowledge that's being sent my way. I pick up the unit on Thursday and post some pics. Been unable to pick it up since I've been a little busy at Road Atlanta for the Petit Lemans. Been on Onan NHM power from Tues - Sun without a glitch.
Excited to begin a new project with the JC. Hopefully, it will be a simple return to life for the genset. If all checks out good, I plan on installing a new concrete pad behind the house, constructing a weatherproof housing and running a new NG line to it. Good opportunity to run NG to the kitchen for a gas stove in the future. Currently only use gas for heat. Plan on running a 1" pipe from the meter to the genset and a 3/4" pipe to the kitchen. The gas meter/regulator is about 30' away from the genset's final resting place. Comments?
Old 10-09-2017, 01:45:58 PM
NHM ....... If it's been sitting for few months clean the slip rings before making AC , it stresses the AC votlage reg. In my testing ohms thru the brushes increased from ~ 23 to 100 ohms after 3-5 months of sitting. And running it ~ 1 hour w/o reg only lowered it ~ 10%/ Onan says clean at 30 ohms.
Old 10-09-2017, 02:15:07 PM
Thanks for the advice, but the NHM has been with me for a long time. Run it every 30 days for an hour or more and verify the slip rings every year. Just had the geny out and polished the slip rings to a bright copper finish with a Scotch Bright pad. I understand all too well how those dirty slip rings will destroy a VR. A few years ago I failed to do my monthly service and fired her up and put her under full load. The next time I tried to use it I had no AC output. It ended up costing me a VR. When I checked the resistance of the slip rings it was just over 100 ohms. At $300 a pop, they're not something I like to replace very often. Ever since then, I got into a regular maintenance mode and have never had another issue.
Old 10-09-2017, 02:30:14 PM
I have a NHM, nice thing is unlike NHE types it will run even if it doesn't make AC .
With reg unplugged so it can't make AC, I just run engine and hold a scotchbrite pad under the slip rings. For a holder I cut off the 2 side tines of 4 tines off a kitchen fork, and jabbed strip of scotchbrite on end , and tied other end of strip with cotton string.
PITA to unplug reg so I plan on adding a switch toopen the line from controls to flashing pin 7 of reg, that will prevent stop the boot strap process of gen starting to make AC. Was thinking of putting one of those military type red "Toggle Switch Guard Covers" over it, so it will be obvious that normal position will be cover closed ( switch on)
Old 10-09-2017, 04:01:20 PM
Jim Marcozzi Jim Marcozzi is offline
No synthetic oil- not necessary and won't offer any advantage. Stay with something such as a good brand name 5W30 or 5W40. I run Baldwin filters.
Keep a spare regulator handy. The YD's will eventually fail and it's usually when it's really needed and not during an exercise.
Check the lower electrical box for rodent damage and use expandable "fire foam" to fill all voids in the boxes so mickey mouse can't get in and jack things up.
Check/adjust valve lash. Install & gap new plugs. Check over the rest of the ignition secondary. Clean the "run" contacts under the cover. Clean/replace the ignition points and set properly, along with timing.
Load at least 50% rating and when warm, set RPM to 60.2-60.5 Hz. Adjust voltage.
Take the charge resistor out of the YD's cooling duct and bead blast the resistor's exterior and the clamp. They get corroded and you lose 12V charge. Once assembled, run get with a charged battery and set voltage to about 14.0-14.4V at the battery when running.
And importantly.....always remove the air cooling covers several times per year and inspect for mouse nests. They LOVE to build nests around the jugs and other hidden places. Running them with nests will starve the engine of cooling air and cause damage in no time.
With some TLC and PM, the JCs will out last you. And me.
Proud owner of a Cub Cadet 108 Garnold Garden Tractors / Mowers / Scooters 3 11-26-2012 08:57:50 PM
New proud owner of a Witte kds Antique Gas Engine Discussion 3 09-17-2008 09:09:10 PM
Proud Owner of a 25 HP Rumely Bob Oliver Steam Stationary Engines, Traction Engines, Steam Boats 17 10-15-2006 07:36:07 PM
Proud New Owner Needs Help Dewey Kohler Generators 1 03-29-2005 04:24:33 PM
