Onan MDJE - looking for documents on electrics
this thread has 8 replies and has been viewed 311 times
Old 10-10-2017, 02:15:00 AM
NomadAU NomadAU is offline
Default Onan MDJE - looking for documents on electrics
Hi,
My marine genset (model 6.0 MDJE-53CR/2268AA) is nearing the time when I'll need to run up the electrics after the rebuild. My plan is to get the diesel running first, then attach the generator component once I'm happy that the donk is running ok.
So, I'm now taking a lot more interest in the electrical parts, and it would be a great help if I understood a bit more about how it works. I'm pretty sure I don't have a magneticitor (spelling?) version, and I can't see any brushes. I've attached a pic showing the 3 main components that move, or hold the moving parts so that the type of generator can be clearly identified.
Does anyone have a document that explains how how my genset works, i.e. what physics it uses to generate electricity? My guess is that it's similar to an automotive alternator but I'd really like to know a bit more detail.
Also, is there a manual out there that has clear wiring diagrams so that I can reassemble the 'non-moving' parts of the generator, e.g. control panel, big resistor, etc. ?
Cheers,
Mike
Old 10-10-2017, 02:37:48 AM
Ray Lynch Ray Lynch is offline
Default Re: Onan MDJE - looking for documents on electrics
Spec AA is a brushless YD generator. Others will be along with link to the manuals and schematics.
Ray
Old 10-10-2017, 06:40:37 AM
MBB MBB is offline
Here is the build sheet and wiring diagram.
The Following 2 Users Say Thank You to MBB For This Post:
Old 10-10-2017, 06:45:48 AM
Kevin K Kevin K is offline
I'm attaching the production order and wiring diagram for your 6.0 MDJE-53CR/2268AA generator. I'm not sure if this is a YD generator end or not. The AB and later spec codes show up as using a YD generator end. My guide lists the following manuals for a Spec AA MDJE:
968-0220 parts
968-0562 service
Someone who has experience with this generator should be able to give you more information.
The Following 2 Users Say Thank You to Kevin K For This Post:
Old 10-10-2017, 07:05:03 AM
MBB MBB is offline
PM me and I will send you he YD manual. It will be of some help explaining things. Or look for 900-0184
Old 10-10-2017, 09:18:57 AM
Billy J Shafer's Avatar
That is the YD class generator. Everything you need to know will be in the manual MBB will send you
Old 10-10-2017, 09:59:15 AM
Dale Russell Dale Russell is online now
We hope you are feeling better Billy! Hang in there, we know you are a tough old bird.
Old 10-10-2017, 11:03:32 AM
Thanks Dale. I managed to get some real food down last night. Able to sleep without soaking the bed. Chills are gone.
I was thinking about the Marine manuals and remembered this one. Got it at the factory training class. Can't find my manual list back of this one is torn but last numbers are 0405. Covers diesel and gas. Very good manual to have. I see them on ebay at times.
Old 10-10-2017, 06:00:41 PM
I asked, and I got!
Thanks to everyone for providing all my latest reading material. It really is a great help to be able to read (and re-read) this stuff at the same time as putting the bits together. Thanks again.
Cheers,
Mike
Rumely 6 Electrics Richard Sturdy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-29-2011 11:19:54 PM
documents Aevry Small Air Cooled Gasoline Engines 2 10-26-2010 03:45:00 PM
Onan 30.0EK-3R Generator Documents DGrim Onan Generators 7 03-11-2010 12:07:41 AM
Onan 4.0 CCK-3CR/8100R electrics Dodger Onan Generators 5 06-29-2007 06:05:51 PM
