Onan 4000w 4.0bf3cr16000b (R1 Resistor)
this thread has 53 replies and has been viewed 1796 times
Old 10-10-2017, 11:49:59 AM
JohnnyJeeper JohnnyJeeper is offline
Default Onan 4000w 4.0bf3cr16000b (R1 Resistor)
Hello all,
I had an issue with my old gen...only run while holding start button, traced it to a bad R1 resistor replaced it and it started right up and ran great for a few hours then started the same symptoms, only run while holding the start button, the new resistor I put in looks like it started to melt...what would make the new resistor fail like that? Should i be looking at some other source of the issue? Any insight here would help a lot, been workin on this old thing fo awhile.
Thanks, J
Old 10-10-2017, 01:16:18 PM
len k len k is offline
Default Re: Onan 4000w 4.0bf3cr16000b (R1 resistor)
If it was same type and size as original you might need to put it into an airflow. I'm not too familiar with which one R1 is on a BF. But if it's the bat charge resistor, it may be a 25 watt resistor dissipating 50 watts, and needs forced cooling from an airflow. Bat charging resistor on similar NH models are by the fan near the brushes.
Old 10-10-2017, 04:13:55 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
On my BF 3CR/ 16002b 4KW The R1 charge resistor is onan part number 353-0057 and it is back on the generator end by brushes Maybe check to see if you got a bare wire causing a short be sure all brush wires are in the right place check wiring diagram.
I am thinking 5 ohm 25 watt resistor
The Following User Says Thank You to Onan Dan For This Post:
Old 10-10-2017, 04:28:01 PM
I checked all brush wires good no bare wires that i see...all checks out good except the resistor, that is the exact one I installed 353-0057...could a bad voltage reg cause the resistor to heat and fail? Doesnt seem like it would be the issue but i am stumped at this point, could it just be a bad resistor out of the box? I think it said on the box it was made in 2009.
Thx
The Following User Says Thank You to JohnnyJeeper For This Post:
Old 10-10-2017, 05:07:21 PM
Onan Dan's Avatar
Johnny you change the resistor start it and with your volt meter see what the dc voltage is I have not looked at my BF charge for sometime I am thinking it may of been like 18 or 19 volts dc kind of been taking care of my wife and have not been in the garage for sometime I hope she gets better still and then I can get back to my true love GREEN MACHINES but do not tell my wife
Old 10-10-2017, 05:18:57 PM
Thanks Dan,
Hope all is well with the wife...and hope you can get back out in the garage soon!
So install a new resistor and while running test DC voltage from where? Sorry to be stupid here just learning about this old girl...
Old 10-10-2017, 05:28:19 PM
No voltage regulator on a BF. Diode and adjustment (two choices on wiring hook up) on the resistor you changed.
Old 10-10-2017, 05:41:34 PM
Check that CR1 charging diode is good. If shorted then resistor may draw hi amps when engine is off.
How's your bat, dead cell maybe and bat only making 10V instead of 12V?? That would increase current thru resistor. Check bat voltage after bat has sat for about a day without use or charging.
If RPM (hz) are high that would increase bat charging amps, but 120VAC voltage would be high also.
Old 10-10-2017, 06:36:00 PM
Onan Dan's Avatar
like was mentioned there is no voltage regulator on the BF easy to check 12 vdc currant you can check it at the resistor positive on the resistor wire and grd to grd also when running you can test for dc volts at the fuel pump or on electric choke the running speed of the generator determines the voltage ac or dc 1800 rpm 60 hertz 30 rpm per hertz times 60 equals 1800 rpm I run my BF around 124 volts ac so it would be a little over 1800
Old 10-10-2017, 06:37:33 PM
Just installed 2 new 6v golf cart batteries those are good to go...could a bad charge diode cause the resistor failure?
Someone educate me about resistor and non resistor spark plug caps Motorhead Onan Generators 19 11-05-2016 08:17:41 PM
Onan 4000w questions. oldsman Onan Generators 5 09-25-2015 01:24:19 PM
Does my Onan 4BGE 4000w running sound normal? imorton Onan Generators 4 10-08-2012 02:55:16 PM
Onan 4.0 cck resistor Coldshot Onan Generators 44 09-15-2012 05:28:59 PM
1991 Onan Emerald 4000w Buzzing Sound soybot Onan Generators 4 04-17-2012 06:40:48 PM
