Reliance 510A Transfer Switch
this thread has 19 replies and has been viewed 553 times
Old 10-10-2017, 02:58:14 PM
JT240Z JT240Z is offline
Default Reliance 510A Transfer Switch
Just curious if anyone has used one of these. At 50 amps it's a little shy of what the JC can put out but close enough I think for my needs. It's the 10 circuit manual transfer switch.
http://www.reliancecontrols.com/ProductDetail.aspx?510A
Old 10-10-2017, 03:29:58 PM
Billy J Shafer's Avatar
Default Re: Reliance 510A transfer switch
Looks good on paper. But I would want to see one in person. Make sure it is not some cheap pile of tin and plastic.
Old 10-10-2017, 04:27:29 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Make sure it is not made in China.
The 510A is 12500 watt with 10 circuits.
The Control panel
and gauges of my
7.5JB
Old 10-10-2017, 04:36:56 PM
We used to install a lot of Reliance Control "load side" transfer switches. At the time, the largest ones they had were for maximum 30 amp input and a maximum 20 amp branch circuit. A popular model was their 30310, which would give you up to 10 branch circuits. I installed one of these for my next door neighbor several years ago. Two of the SPDT switches went bad over the years. Fortunately, I had some in my junk...er "miscellaneous goodies" bin that I was able to replace the defective switches with. I disassembled the defective switches, and was able to repair them so my neighbor would have spares. They weren't burnt up or damaged, but just wouldn't make contact internally. It looked like the contacts were tarnished. A little cleaning and tweaking brought them back to life, but it's frustrating when one of your house circuits doesn't work. The original style switches that Reliance used held up better than the newer style switches.
I recently installed a mechanical interlock on the neighbor's 200 amp service panel, and bypassed the Reliance switch altogether. Since your JC will produce a fair amount of power, have you considered installing a mechanical interlock on your panel, with a 60 amp double pole breaker to feed gen power to the main bus?
The Following User Says Thank You to Steve Dawkins For This Post:
Old 10-10-2017, 05:52:53 PM
Well, it may not be an Onan but @ 17lbs it's not made completely out of plastic. I have yet to see one in person but all the reviews have shown it to be quality. I like the reconfigurability of it. 10 circuits should be good for most emergency needs. I figure the essentials for myself would be:
Well Pump: 12amps@240V (Intermittent use)
NG Heating System: 9 amps@240V
Living Room Outlets: 50 amp@120V (Includes aquarium and entertainment system)
Living Room Lights: 5 amp@120V
Bedroom outlets: 12 amp@120V (Includes ceiling fan, Window AC and Sat TV system)
Kitchen Fridge: 7 amp@120V
Freezer: 6 amp@120V
With a little load management that is.
I have thought of using one but haven't found a mechanical interlock that would adapt to my existing breaker box. Feeding the main with a 60 amp breaker would be a good solution but without a viable mechanical interlock It would be more difficult (total transfer switch) or dangerous (no interlock) then I would like. This seemed like an easy way to add all the circuits that I need and still be safe and a relatively easy install.
The genset does come with an Onan transfer switch but it's 3 phase and I don't know yet if it's changeable.
Old 10-10-2017, 05:57:31 PM
MBB MBB is offline
I have one of them I believe its 6 circuits. Only 120V. It actually works very well. It has an outlet in it for a twist cord. I removed it and put a cover over it or disconnected the wires I forget. The meter is nice so you can get an idea of the load you have on it. I have yet to hook up any of my transfer switches because I never permanently hooked up any of my Onans. It is easy to load manage providing you have separate circuits. If the power comes on you just flip the switch back to line. It is also pre-wired. You are bound by the length of greenfield unless you put in a junction box.
Old 10-10-2017, 06:11:10 PM
I don't know what brand or style of circuit breaker panel you have. If it has a main utility breaker, this company can probably fabricate an interlock kit. They build them to order. "www.interlockkit.com" The kits are recognized by a certified testing agency, so they should be ok with the local inspection authority.
If you have a split bus panel, you will be better off with the Reliance switch.
Old 10-10-2017, 06:35:00 PM
MBB MBB is offline
No need for an interlock. The units are a double throw switch for each circuit. In normal operation the breakers are in the line position. If you want to run them from the generator you switch it from line to Gen. In the center position it is neither Line or Gen. That way you can manage your loads turning a switch to the center.
The Following 2 Users Say Thank You to MBB For This Post:
Old 10-13-2017, 11:50:47 AM
Found a different solution from Reliant that may be a better match for my genset. It handles generators up to 60amp 15K watts and supports up to 12 circuits. Utilizes an interlock system with a 60 amp breaker on the generator side and a 100 amp breaker on the main side.
http://www.reliancecontrols.com/Prod...spx?TRC1006CP9
Northern tool carries it for $375
Old 10-13-2017, 10:45:14 PM
AngrySailor AngrySailor is offline
That must be one HECK of an aquarium and entertainment system!
mep 016d wiring to reliance transfer switch oklahomabob Military MEP and Aircraft Gen-Sets 0 09-30-2015 04:30:52 PM
Reliance Manual Transfer Switch Q-Series vdrive Onan Generators 4 12-17-2013 07:04:31 PM
New Generac XP8000E w/ Reliance Transfer Switch Issue jlegan Generac Generators (SEARS, etc.) 38 08-12-2013 07:54:40 AM
Reliance Switch with my Honda powerking Generators & Electric Motors General Discussion 3 04-19-2013 02:47:03 PM
Reliance Transfer Switch powerking Generators & Electric Motors General Discussion 11 11-05-2012 11:16:53 PM
