Homelite 23A
this thread has 3 replies and has been viewed 577 times
Old 10-12-2017, 10:24:17 AM
Ed Stoller Ed Stoller is offline
Default Homelite 23A
I have a Homelite, Model 23A 115 2, S/N 291242 and am looking for manuals and parts. The parts I need are the fuel pick up tubes and ball check valves. Any help fining a source would be appreciated.
Sorry, posted in wrong place. Moderator please move..
ID:	293368   Click image for larger version
Old 10-12-2017, 10:47:45 AM
AngrySailor AngrySailor is offline
Default Re: Homelite 23A
I rescued one of these from a scrap pile not long ago. There's a thread somewhere here called "small homelite generator" (I think) and there was some talk of the fuel system. I haven't had a chance to play with mine yet so I cant be of much other assistance but the smart guys will be along shortly I'm sure.
Old 10-12-2017, 09:47:33 PM
s100 s100 is offline
It's highly unlikely that you will come across any parts for that engine unless you find a donor machine. You'll probably have to make them yourself. As to a manual, I suspect the closest you will come is to get an old copy of "Small Engines Service Manual" by Howard Sams/Intertec Publishing. The ninth edition has all the information you need, I think. That edition was published in 1969 so the best you will be able to do is to hunt around used book purveyors until you unearth one. Going from memory (I have a 24A115-2 and a 24S3 pump) the tubes you need aren't too complicated and should be easily duplicated from small brass tubing.
Good luck!
Old 12-15-2017, 11:01:41 PM
SlowOnan SlowOnan is offline
I just acquired same model S/N 291211. I have not dug into it yet but looks to be in pretty good shape. I too would love a manual. I read that the fuel system is pressurized (like old outboards) so those dip tubes will need to be correctly made and attached as well as no leaks when tanks put back together. Good luck!
homelite hru 28 12voltdc Military MEP and Aircraft Gen-Sets 5 01-20-2013 08:13:24 PM
homelite hru 28 12voltdc Military MEP and Aircraft Gen-Sets 0 12-15-2012 07:03:01 PM
Homelite Bow saw Roger101 Chain Saw Collectors 8 04-22-2012 08:43:27 PM
Homelite Gen Set Don Nelson Generators & Electric Motors General Discussion 0 03-01-2004 11:22:18 PM
Another Homelite Matt Fretwell Generators & Electric Motors General Discussion 1 02-14-2004 08:14:57 PM
