Onan 12.5 JC Generator with Beam T50 Demand Regulator
this thread has 4 replies and has been viewed 249 times
Old 10-12-2017, 09:05:52 PM
DNL DNL is offline
Default Onan 12.5 JC Generator with Beam T50 Demand Regulator
Will this combo work? I received the generator with no regulator, just a cutoff hose from the carb (the propane equivalent anyway).
I have the regulator on an old 11 hp floor scrubber, would like to use it just to get the generator running. Is it worth trying?
Old 10-12-2017, 10:01:59 PM
reid070 reid070 is offline
Default Re: Onan 12.5 JC Generator with Beam T50 Demand Regulator
It should work fine. Does the t50 work on the other engine? I run a beam t60 on a 7.5 jb and it works great. Is there any other connection from the t50 to the engine? I'm not familiar with the t50 but some models of t60 have a vacuum lock that connects to a source of engine vacuum before it will allow gas to flow.
Steve
The Following User Says Thank You to reid070 For This Post:
Old 10-12-2017, 10:58:39 PM
DNL DNL is offline
Yes, it has a vacuum line for the lock. I'll give it a shot. I just want to get the generator to run, then I'll go from there.
Old 10-12-2017, 11:07:08 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
Originally Posted by DNL View Post
...I just want to get the generator to run, then I'll go from there.
Quickest way is to squirt some gasoline down the carb...
Old 10-13-2017, 07:25:51 AM
Charley K Charley K is offline
t50 is rated to 60hp, same as the t60
The Following 3 Users Say Thank You to Charley K For This Post:
Cummins Onan RS12000 Demand Regulator sierratim Onan Generators 16 01-21-2015 10:16:51 PM
Onan 12.5JC-3CR Needs NG Demand Regulator trawlerguy Onan Generators 22 01-25-2014 11:36:40 AM
Onan 10.0cckb-4r/12b demand regulator VTVolt Onan Generators 5 12-27-2013 01:36:37 PM
Demand regulator for a Kohler K330 Generator gsprice Kohler Generators 0 10-03-2011 08:59:51 AM
NEED LP gas demand regulator for JC Onan High Tech Ken Onan Generators 15 09-17-2009 08:22:46 AM
