Onan MDJE - what is this part?
this thread has 10 replies and has been viewed 452 times
Old 10-12-2017, 09:58:19 PM
NomadAU NomadAU is offline
Default Onan MDJE - what is this part?
Hi,
Can someone help me to identify this part that is left over from my rebuild?
It seems to be either an oil coupling or fuel coupling but I can't figure out where it goes.
Cheers,
Mike
Old 10-13-2017, 01:03:54 AM
Billy J Shafer's Avatar
Default Re: Onan MDJE - what is this part?
Looks like part of the fuel return line.
Old 10-13-2017, 07:23:28 AM
MBB MBB is offline
Maybe it screws into the block and the oil pressure gauge threads on to it??
Old 10-13-2017, 08:04:45 AM
PopsGarage PopsGarage is offline
My guess,,, oil line restrictor to limit oil flow to the cylinder head?
Bob
The Following User Says Thank You to PopsGarage For This Post:
Old 10-13-2017, 02:25:23 PM
BigBlockChev's Avatar
Looks like this to me, fitting into the injector, but you must have started off with a spare if the generator is assembled already. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 3 Users Say Thank You to BigBlockChev For This Post:
Old 10-13-2017, 06:49:43 PM
Gunny Gunny is offline
Many years ago, while still working in the shop (before I got to venture out in public) we'd play with each other and slip in an extra part or two for the mechanic to "find" when he had the engine most;y together.
Sometimes they catch on right away and toss out the extra part. A couple of times they'd start to take it back apart. Valve keepers were a popular "spare" part for this. Pretty obvious if you slipped them a conrod or oil pump, but an oil pump drive spider was good too. Some guys had no sense of humor, some did, one guy threw a real fit and was left alone forever.
The Following User Says Thank You to Gunny For This Post:
Old 10-13-2017, 10:30:57 PM
AngrySailor AngrySailor is offline
The "extra parts" gag is always a good one, BUT I always thought it was worse to not have ENOUGH parts... Now you're left wondering what you put where it doesn't belong This gag works best with things such as automatic transmissions or anything with lots of thrust washers that are easily mixed up
The Following User Says Thank You to AngrySailor For This Post:
Old 10-13-2017, 11:29:16 PM
JohnnyC JohnnyC is offline
The worst is trying to put together cheap-azz furniture made in China. When reading badly translated directions with piss-poor pictorial drawings where all washers and screws look alike in the drawings and trying to match up the actual hardware, I always seems to have left overs.
JohnnyC
New Jersey
Old 10-13-2017, 11:39:21 PM
Then you get those cheap-azz allen keys that come with the cheap-azz furniture accidentally in2 your tool box and wonder why you twist, break and strip them
Old 10-13-2017, 11:47:06 PM
Wow! dead on about those cheap-azz allen keys. I also hate when I overtighten the cheap-azz allen bolts which pulls those cheap-azz stud nuts out of the cheap-azz fake particle press board too.
JohnnyC
New Jersey
What is this Onan MDJE part for? NomadAU Onan Generators 4 10-08-2017 04:59:07 PM
Part Number for Onan AJ part needed Hummer Onan Generators 2 08-02-2014 01:52:26 PM
Onan CCKA part manual or direction to part number Motorhead Onan Generators 2 12-19-2012 02:17:47 AM
need part for mdje n2qxb Onan Generators 6 11-16-2010 06:24:15 PM
Onan 7.5 MDJE - 3CR Help LarryGlover Onan Generators 11 07-19-2007 04:38:12 PM
