Need Service Manuel - Onan 4.0 BF-3CR/16000 RV Gen
this thread has 26 replies and has been viewed 7593 times
Old 09-27-2009, 04:15:14 PM
kelly monroe kelly monroe is offline
Default Need Service Manuel - Onan 4.0 BF-3CR/16000 RV Gen
I was given a 75 Monaco Motorhome in really great shape but the generator is running a bit rough. Found a bad plug, replaced it and runs better but not great. Mostlikely need a carb cleaning. Good spark but smokes a bit.
So after I it going I reved up the motor to see if the smoke would clear and on side if the generator output is out. One leg is 133v the other side is .08v. By looking at the generator stamped plate...it is a 240v unit with 2 legs of 120v So I assume that I blew out the stater or a doide.
Got any ideas on what went wrong and a service manuel on .pdf
Thanks guys for the look!
K
Old 09-27-2009, 08:05:40 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Need Service Manuel - Onan 4.0 BF-3CR/16000 RV Gen
Kelly, with the information you posted, it would seem that you either have an Open Circuit on one Output Leg, OR your Genend is wired as a 120 Vac ONLY Genend. The only way to tell, is to dig into the Connection Box, and see how the Twin Stator Windings are connected to the load. You will have four (4) Stator Wires, labeled M1, M2, M3, & M4. M1 & M2 are one Stator Winding, and M3 & M4 are the other. If you are wired M1=Leg 1, M2 & M3= Neutral, and M4=Leg 2, then your wired for 120/240 Vac. If your wired M1 & M3= Leg 1 and M2 & M4= Neutral then your 120 Vac Only. If your wired M1=Leg 1, M2 & M3 connected together, but Isolated, and M4=Neutral, then you have 240 Vac Only. If you truly have an Open Stator Winding, then your going to need a new Stator, or get your rewound. None of this has anything to do with any Diodes, or the Exciter Winding, as if that were then problem, you would NOT be able to electrically Start the Genset, as the Starter System is ALSO the Exciter System, and your getting 120 Vac out in one place already.
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 09-29-2009, 05:17:22 AM
Thank you very much BTPOST! That gave me a good understanding on where the issue is.
I plugged in the power cord to house current and low and behold 1/2 of my circuits are not working....not a generator power out put issue after all but rather a power distrubutor lost one side.
You are correct I have a 120v ONLY system.
Thank you for the wireing diagram...after some shuffling though the paper work that came with the RV I found the original Service Manuel which really goes into some detail on the unit. It's loud but it works good. Still need to tackle the carb...I think it's flooding a bet.
When I get sometime I will scan in the manuel and email it to you to pass on at will.
Thanks again for the input!
Kelly
Old 01-30-2014, 07:59:01 PM
AngelicaParker AngelicaParker is offline
Default Re: Need Service Manuel - Onan 4.0 BF-3CR/16000 RV Gen
Hi, I was wondering if I could get a manual for an onan genset 4.0 generator
model #: 4.0 BF-3CR 16000B
serial #: I 763198408
thank you very much
Old 01-30-2014, 09:03:37 PM
If you will give us a place to send it, we will give you a manual. Fair trade, even swap.
The Following User Says Thank You to Max Thompson For This Post:
Old 01-30-2014, 09:06:44 PM
John Ward John Ward is offline
thank you very much
Someone will be along with the manuals that you need. Here is the build sheet for your generator.
The Following User Says Thank You to John Ward For This Post:
Old 01-31-2014, 12:36:38 AM
lol...ty, I forgot to add my email address...sorry. angelica.parker@ymail.com
Old 01-31-2014, 08:16:45 AM
Service & parts manuals should be on their way.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 01-31-2014, 05:09:58 PM
wxyoung2008 wxyoung2008 is offline
Email NOT Working
Thanks MAX THOMPSON !!!!!
The Following User Says Thank You to wxyoung2008 For This Post:
Old 02-04-2014, 10:41:47 PM
thank you very much
Regarding the Quoted post above..
My husband needs the manual, or some kind of instruction/detail, to remove and reinstall the starter on the onan generator (specific details of the generator are within quoted above).
It would be greatly appreciated for any help you could lend to us. Thank you very much. (incase needed: angelica.parker@ymail.com)
Onan Service Manuals B.Ikard Onan Generators 134 09-22-2012 10:23:35 PM
Re: Onan Service Manuals Ohnan Onan Generators 0 09-06-2009 05:18:52 PM
Onan NHE service manual 300LE Onan Generators 2 03-10-2009 06:40:01 PM
Onan cck repair manuel/help needed richt Onan Generators 2 08-17-2006 06:57:22 PM
Onan 25hn-3r Need service manual Rusty Bob Onan Generators 2 11-15-2005 02:00:42 PM
