Smokstak Down Under
Fuller and Johnson Lighting plant/ Western electric
this thread has 2 replies and has been viewed 1075 times
Old 12-28-2014, 05:20:22 AM
choofer choofer is offline
Default Fuller and Johnson Lighting plant/ Western electric
Hi, I am having trouble tuning the engine on this unit. All work has been done, but the engine only runs slowly (500 RPM or less) This unit has a magneto and the ignition timing seems to be okay. There is a fuel mixture adjustment screw and this makes some difference it either runs or doesn't when this screw is adjusted, but it won't pick up the RPM. Does anyone have any ideas? Thanks
Old 12-28-2014, 03:19:31 PM
Nick's Avatar
Nick Nick is offline
Default Re: Fuller and Johnson Lighting plant/ Western electric
Check the governor. Make sure the spring is not broken and that the whole system is complete and adjusted properly.
Old 12-29-2014, 03:35:22 AM
Thanks Nick, it is running well now, the issue was the push rod for the governor had been replaced and was too short. I appreciate the help. I am as happy as a pig in mud with it, everything is working well.
Western Electric / Fuller & Johnson 15B Lighting Plant Parts Needed MBreen254 Generators & Electric Motors General Discussion 8 09-09-2017 10:26:39 AM
Fuller and Johnson lighting plant choofer Smokstak Down Under 6 12-13-2014 02:20:29 AM
Fuller Johnson Special Electric maybe Rustaholic Unidentified Engines 2 06-14-2011 06:42:09 PM
Need Info: Western Electric 32V light plant Bob Painter Delco and other Low Voltage DC Light Plants 20 11-12-2008 09:38:25 AM
Fuller Johnson light plant NICK Antique Engine Archives 0 08-29-2002 06:36:57 AM
