Lister lighting plant
this thread has 5 replies and has been viewed 1037 times
Old 12-22-2016, 05:42:44 PM
Polishbuilt Polishbuilt is offline
Default Lister lighting plant
Good evening all....could anyone help with my recently purchased 1.5 kW set.im unsure as to where to connect a rheostat as yet I cannot get her to produce any volts.
Old 12-22-2016, 06:47:07 PM
Neville Bond Neville Bond is offline
Default Re: Lister lighting plant
That looks familiar :-)
Old 12-22-2016, 06:59:20 PM
Vanman Vanman is offline
Wow, that looks neat!
How many wires are coming out of the generator and what size are they?
It looks like the generator is direct current, correct?
Keith
Old 12-23-2016, 12:47:09 PM
Radiomike Radiomike is offline
That is a nice set. I think I can see three data plates, engine, generator and frame.
What they say will be the key to the whole connection and the wiring you need. AC and DC generators both need field connections, how they are connected will be different. A search for Lister schematics will reveal lots of information, you just need to know what model.
Did you get a switchboard or control panel with the unit?
Mike
Old 12-23-2016, 02:12:52 PM
I think it's DC because it appears to have interpoles.
Old 12-23-2016, 08:17:35 PM
It does indeed look like it has four poles with larger bolts and four poles with smaller bolts. It is missing a control panel.
With three data plates it should not be too hard to work out what it needs.
Mike
Lister Bruston Automatic Electric Lighting Plant Renovation question Jensma Lighting Fixtures, Switch Panels and Meters 11 06-25-2016 04:36:04 AM
Lister Bruston Lighting Plant Restoration Jensma Antique Engine Photos 1 03-14-2016 05:57:44 AM
Davey Lighting plant Pettergen Smokstak Down Under 0 01-05-2015 07:38:47 PM
F/M home lighting plant Bill Antique Engine Archives 13 08-07-2003 10:55:03 AM
Matthews Lighting Plant S. Williams Generators & Electric Motors General Discussion 2 05-01-2003 10:24:48 AM
