1912 Stover ODX Fuel Valve Before Mixer
this thread has 1 replies and has been viewed 518 times
Old 05-12-2018, 06:19:47 PM
EMU EMU is offline
Default 1912 Stover ODX Fuel Valve Before Mixer
This check / ' value ' valve or fuel control valve , does it look complete . The fixture at the lower part of image has 2 fine holes diagonally at the top portion of the shaft . As you can see its other end has a cone shaped cup . What part does the role of the holes in the shaft ...
Name:	stover valve.jpg
Old 05-12-2018, 06:32:00 PM
EMU EMU is offline
Post Re: 1912 stover odx fuel valve before mixer
I am tending to , understand that this valve would 'tilt off its seat allowing fuel to mixer ' . Once Engine is ' stopped' the pin' would fall back to its seat . Then the holes in the 'shaft ' would allow fuel to drain from the bowl ... leaving no fuel in the system . it is not a total shut off check valve . It seems to allow fuel to slowly drain back to tank,
Tall Glass Fuel Gauge w/ Needle Valve Mixer Needed ITFormulaGuY Carburetors, Mixers, Fuel Pumps and fuel delivery 6 08-17-2019 08:16:23 PM
1912 ODX Stover Fuel Pump Question EMU Hit & Miss Gas Engine Discussion 8 06-16-2018 05:57:32 AM
stover type k fuel mixer help please (ke243144) DDean Hit & Miss Gas Engine Discussion 7 03-28-2017 01:15:50 PM
Does anyone have a picture of a fuel mixer for a 6-8 hp Stover KC Mark S Frank Hit & Miss Gas Engine Discussion 11 11-07-2009 12:29:19 PM
1912 Stover YB Larry K Hit & Miss Gas Engine Discussion 5 05-21-2006 10:48:15 AM
