Tiny Tim Battery Charging Set
this thread has 13 replies and has been viewed 2079 times
Old 01-23-2018, 12:36:34 PM
Tim Venetis Tim Venetis is offline
Default Re: Tiny Tim battery charging set
Originally Posted by Vanman View Post
That 60 amp meter would make me tend to think that it is a 6 volt set. 60 amps at 12 volts would be more power than that little engine could make, I'd think! This, of course, assuming that the gauge is original....
Keith
Hi is the tiny tim a b circuit or a circuit configuration thanks.
Old 01-25-2018, 12:16:59 AM
I did some probing and found out the wards airline charger has a a circuit configuration and the tiny tim charger was another name for the wards charger. From my understanding Western Auto also sold the same charger under another name Wizzard Light Plant.
Old 03-17-2018, 08:28:01 PM
brownfrog brownfrog is offline
Default Re: Tiny Tim Battery Charging Set
Hello:
I am in the same pickle. no tags or ID info. One way to see what voltage it puts out besides the smoke test is to find the cutout relay and see what voltage across its coil will cause it to close starting with the lowest possibility, 6 volts in this case. It is probably lurking under the metal cover on the side. The cutout relay coil is connected across the output of the generator and pulls in when the generator voltages equals approacjes and exceeds the battery voltage. I did not know that they made a 24 volt plant. They also made a 32 volt device. I need to machine a part for the pesky pushbutton switch on top. Contact us if any questions. Cheers!
Old 03-17-2018, 10:20:54 PM
Originally Posted by brownfrog View Post
Hello:
You could try starting it on 6 volts and disconnect the battery and see what it puts out fromm the battery terminal on the voltage regulator.
Tiny Tim Battery Charger bartlett0815 Small Air Cooled Gasoline Engines 7 12-17-2017 10:13:13 PM
Tiny Tim Generator/Battery Charger John Schwiebert Generators & Electric Motors General Discussion 23 05-18-2017 01:21:13 PM
Tiny Tim Battery Charger Wiring skeeter Generators & Electric Motors General Discussion 0 02-24-2011 12:38:49 AM
Battery Charging AndyG Trucks, Trailers and Hauling for Shows 10 09-25-2005 04:27:33 PM
Tiny Tim battery charger JBailey Small Air Cooled Gasoline Engines 3 05-05-2005 08:22:35 AM
