Delco 751 running problems
this thread has 22 replies and has been viewed 1777 times
Old 09-10-2017, 12:46:30 PM
Tribute Tribute is offline
Default Re: Delco 751 running problems
Still interested in I think Delco 750 if anyone can enlighten please. Thank you for all your help so far. Keith
Old 09-11-2017, 06:49:50 AM
FDChief FDChief is offline
I don't quite understand what you're asking for. The model 750 has a small starting motor next to the flywheel. The 751 uses the generator to crank the engine. I have reprint manuals for both if you're interested in one
Jeff
Old 09-11-2017, 02:49:35 PM
Thank you for that information I now know at last that my engine lighting set is a 751 probably from 1921. As you can see it is in brilliant condition and runs superbly lighting a delco 600watt of bulbs on a board. If I need the manual I will certainly contact you again. Once again many thanks. Keith
1.5hp New Sattley Running Problems dcwaller66 Antique Gas Engine Discussion 7 03-26-2015 02:47:53 AM
IHC Famous running problems freshieslures Antique Gas Engine Discussion 9 03-02-2013 08:52:01 PM
92 running problems again Jason1330 Maytag Engine Collectibles 10 11-18-2009 10:46:15 AM
AC Delco regulator problems David Dice Generators & Electric Motors General Discussion 2 09-11-2007 10:27:02 PM
Amanco running problems R. Goodacre Antique Gas Engine Discussion 8 04-18-2005 08:21:11 PM
