Stearns Light Plant
this thread has 10 replies and has been viewed 948 times
Old 08-05-2017, 07:32:42 AM
Noyes Noyes is offline
Default Stearns Light Plant
Found some Stearns sales literature post marked 1929 from West Virginia USA.
ID:	287944   Click image for larger version
ID:	287945   Click image for larger version
The Following 6 Users Say Thank You to Noyes For This Post:
Old 08-05-2017, 07:45:34 PM
Default Re: Stearns Light Plant
That's in very nice shape. I don't believe I've seen antique advertising in better condition anywhere. Mind if we ask where you got it?
I've always considered a "double sided" picture frame for display, but never built one. That way you could hang it with either side showing.
The Following User Says Thank You to George Andreasen For This Post:
Old 08-06-2017, 10:31:47 AM
I found it on E-Bay. Not much info on this company.
Old 08-06-2017, 11:49:31 PM
clnr94 clnr94 is offline
I have a Sterns Light Plant just like the one in your ad I bought it at the Portland Swap 2 years ago an have it running
The Following User Says Thank You to clnr94 For This Post:
Old 08-07-2017, 01:24:44 PM
There are various prior threads here and on other old-tractor sites re' Stearns; Google Stearns Tractor motor , and search Stearns here---a batch of stuff will show up re' company history etc..
The Following User Says Thank You to Bud Tierney For This Post:
Old 08-08-2017, 03:07:48 PM
cinr94 Do you have any photos or video of your light plant? I have viewed one other video on Youtube of a Stearns running. The plant I have is on Youtube search Allan Noyes and it should come up. Was that the spring swap meet at Portland ? If more Stearns plants are rescued I would like to start a registry of models, serial numbers and owner info.
---------- Post added at 03:07:48 PM ---------- Previous post was at 03:04:01 PM ----------
Bud Tierney I am not sure if the Stearns Light plant and the Stearns engines used in early tractors are related, maybe others can verify.
Old 08-08-2017, 06:09:06 PM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
I appreciate that posting of the literature. I have a 850 plant 32 volt too.
It ran and generated a few years ago for a brief time, but needs a full restoration. It needs the skids made, the radiator cleaned and some brazing on the rad outlet from the cylinder. The head had been welded due to a freeze crack at some point. On my to do list
Its the later version like the picture above.
Mine is serial number 14105
Mike
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
The Following User Says Thank You to Mike Schweikert For This Post:
Old 08-08-2017, 08:36:06 PM
Mike thanks for posting I will start a registry of Stearns Light plants and see what evolves.
The Following User Says Thank You to Noyes For This Post:
Old 08-08-2017, 11:22:15 PM
I will get a video of it running an post it an yes it was the spring swap meet 2016 also got a Phelps from the same guy spring 2015 it's a tank cooled with model t coil for ignition factory setup also have it running
The Following 2 Users Say Thank You to clnr94 For This Post:
Old 08-09-2017, 02:26:04 AM
NOYES: Good question---going over my notes, I didn't note any ad or piece that specifically said they were the same co, except for a light plant piece in Elec Review in 1921 that referred to the light plant builder as a builder of "...light plants and gasoline motors..."...
I very well may've assumed from the light plant and motors ads using the same company name they were, in fact, one company...while it seems a valid assumption, I'm certainly open to correction...
Wed Aug 9 addition---A Gas Engine magazine piece in 1977 (Giles Tractor Notes) does say the light plant co and Stearns tractor engines was same company...but credit should probably go to Wm Giles, an earlier engine and boat designer, who started Giles Engine And Boat Works, later Giles Tractor And engine co in Ludington, apparently with J S Stearns and others financial backing...
Stearns reportedly bought out Giles, who'd produced a line of marine engines as well; the Std Cat farm tractors states the 1918 Gile tractor had a Gile built OHV 43/4 x61/2. So it appears Stearns simply continued Gile engine production, naming them Stearns...
Reports state customers were unable or unwilling to pay in the crash of 29-30, that Stearns was heavily involved in lumber operations in Stearns, KY, and simply decided to shut down the engines operation. ...
The Following 2 Users Say Thank You to Bud Tierney For This Post:
Stearns Light Plant Noyes Delco and other Low Voltage DC Light Plants 24 12-18-2016 01:34:36 PM
Stearns Light Plant Horse Power at 511 Generators & Electric Motors General Discussion 6 11-06-2011 11:17:00 AM
Info on Stearns lighting plant Robbo Generators & Electric Motors General Discussion 6 05-04-2010 08:50:54 PM
Info Needed Stearns Power Plant Josh Downard Generators & Electric Motors General Discussion 0 04-25-2004 04:10:24 PM
