2005 Onan Marquis Gold 5500
this thread has 1 replies and has been viewed 191 times
Old 04-12-2018, 03:58:32 PM
marysdad marysdad is offline
Default 2005 Onan Marquis Gold 5500
Have access to one of these that was removed from a toy hauler that had a tree fall on it (not on the genny, though). Says it was running at the time.
I figured out from the serial number that it was made in 2005. Not able to decipher the model number using the info in the sticky.
Model: 5.5HGJAB-1038D
It is a gasoline model. Trying to assess whether this is worth getting running and convert to propane for use in a fifth wheel. To the good, there is a box of extras that includes a new carb in a plastic bag.
What would be the steps to perform before trying to start it to see if it will run, assuming that it sat a couple of years?
Old 04-12-2018, 04:03:31 PM
len k len k is offline
Default Re: 2005 Onan Marquis Gold 5500
Might want to clean genhead slip rings before making AC. (they oxidize if they sit)
Haven't heard it on these yet , but the older model Marquis design ( BGM/NHM , horzontal shaft design) had a problem with the $245 AC voltage regs dieing if gen sat for months without cleaning slip rings
Onan Marquis 5500 gold problem Duallydriver Onan Generators 4 07-01-2015 07:15:32 PM
Onan 5500 Marquis Gold Fuel Problem live2ride Onan Generators 13 04-20-2015 07:04:32 PM
Onan Marquis Gold 5500 RollOut Transport Onan Generators 24 12-02-2013 07:35:38 PM
Onan 5500 Marquis Gold LP - No Start Ben34mod Onan Generators 21 10-17-2013 01:44:45 PM
Onan Marquis Gold 5500 fault rcmech Onan Generators 2 06-17-2008 08:04:22 PM
