Onan 6k DJB Controller Rebuild/Replace
this thread has 41 replies and has been viewed 4284 times
Old 10-15-2014, 02:07:17 PM
keeper keeper is offline
Default Onan 6k DJB Controller Rebuild/Replace
Onan 6.0 DJB 3R/12482 S Controller rebuild/replace
Ser. 1172528891
Hello, My diesel generator was salvaged from a So. Jersey firehouse. It was pretty rough and hadn't been run in years. I cleaned it up ,replaced glow plugs,filters, ect. I got it running ,and took it to a diesel gen. repair mechanic who did some adjustments to the governor. He load tested it and checked for a 60 hrz. output. Everything worked fine. I got around to mounting it on a platform last spring .I wired up an outlet, and added a fuel guage. I am a 0 when it comes to electrical work, so I attempted to find a electrician to check things out before I fired it up. No one was interested.
Early this month attempted to check it out myself and when I went to connect the ground side of the Bat. it tried to start . I noticed the heater toggle switch broke, I opened the control box and found a mouse nest. the relays were corroded and many of the terminal screw heads were rotted off.
I salvaged what I could but the relays, switches , resistors , lamp holders are shot. I am looking for some direction as to whether to repair or replace the controller or a less complicated fix. My intent is to use the Gen. with outlets and only in an emergency. I have all the manuals. Any help or guidance would really be appreciated.
ID:	208576   Click image for larger version
ID:	208577   Click image for larger version
Old 10-15-2014, 03:31:15 PM
Doug Reed Doug Reed is offline
Default Re: onan 6k DJB controller rebuild/replace
Sorry to hear about the mice, but it tends to be a standard problem. If you had mice in the control box, then you should plan to strip the sheet metal covers off the engine and check inside the generator-end itself for more of them. Plan to invest in some quarter-inch hardware cloth or possibly duct seal for small holes. The best option is a well sealed box or cover until you need to use the generator, but you also need to test run 30 minutes once a week or no less than once a month to keep it in shape and prevent oxidation on the slip rings.....
Most of the parts you mention are fairly cheap items and are available from electronics surplus or catalog sellers. You will probably not find the original Onan part numbers, but should be able to find suitable substitutes. But if you are not into electronics and don't have a good friend who is an electronics guy, then you might have trouble.....
Many people have been in exactly the same position and have managed to rebuild and rewire the control box on their generators, usually for the same exact reason as you. But your generator has been sitting for a long time so be sure to check the brushes and clean the slip rings on the generator before you try to run it.
I haven't looked up the wiring diagram for your generator but I'm sure someone will. You'll want that diagram to rewire the control box. If you decide not to repair it, I'm sure someone will be happy to drive over and haul it away for you. You had it all cleaned up and working before you put it away, so I'm sure most Stakkers would figure this was an easy repair. Personally, I'd say that a diesel JB is a very desirable standby generator and you should fix it up if you can. But this time don't stop until you've got a mouse-proof cage around it.
The Following User Says Thank You to Doug Reed For This Post:
Old 10-15-2014, 04:08:07 PM
nothingbutdarts nothingbutdarts is online now
On a unit like this that has not run in a long time, can you just pull all the brushes, then start the engine to let it run a while and see if the engine is OK first?
The Following User Says Thank You to nothingbutdarts For This Post:
Old 10-15-2014, 04:34:10 PM
You say you've got all the manuals but you can check against this list to be sure.
DJB spec A-AC gensets:
967-0121 Operator's manual
967-0221 Parts manual
967-0751 Engine Service manual
900-0184 YD Generator & Controls manual
Except your build sheet shows you have a Magneciter generator, not a YD. So I'd suggest these extra manuals:
967-0500 JB JC & Magneciter Service manual (just for Magneciter info)
922-0502 Master Generator & Controls Service manual (Section 4)
I've attached the build sheet and the main wiring diagrams.
Name:	6.0DJB-3R-12482S Build Sheet 00040989.jpg
ID:	208596   Click image for larger version
Name:	611-0935 wiring diagram O1A771.jpg
ID:	208597   Click image for larger version
Name:	612-1542 wiring diagram O2A2959.jpg
ID:	208598   Click image for larger version
Name:	612-1786 wiring diagram O2A3202.jpg
The Following 2 Users Say Thank You to Doug Reed For This Post:
Old 10-15-2014, 05:06:46 PM
YellowLister YellowLister is online now
ive had to fix what your looking at.. im not the best with electrical stuff but managed to do it keeping it original... my box was so badly rusted from mice pee and poo I found a good used box from a jc that had water in the engine for years that I swapped over.. I have a few extra boxes with lots of good parts I keep on hand.. I like to keep them original..
parts are out there but costly. Ive actually found all NOS parts for them online for a cost of almost 500... Max Thompson has converted them to newer relays and such for reasonable prices.. so its doable. im sure others have but I just remember seeing his and how nice they are..
Old 10-15-2014, 05:19:44 PM
Leon N. Leon N. is offline
In my experience since you have a Magneciter, do not pull the brushes and run the engine. Doing so may damage your Magneciter beyond repair for a couple of reasons. This machine has automatic field flashing upon startup and (2) if you spin the generator much below 1800 rpm, you will over heat the Magneciter coils. More to,the point, there may be enough residual magnetism to generate some voltage and if spinning much below 1800. RPM, the inductive reactance of the coils will be low and damaging currents may flow through the reactor coils. Just my opinion.
The Following 2 Users Say Thank You to Leon N. For This Post:
Old 10-22-2014, 11:25:56 AM
Hello all,
First I want to thank all of you for your replies. Sorry to let you know I am disheartened because of the devastation of the control box. The Latch, Ignition, Start, emergency, and both solenoids are worthless. I spent quite a bit of time searching replacements. Most if not all are discontinued and are non stocked items from suppliers. Amazon and Craigslist were fruitless. Ebay has the start, ignition,resistors and solenoids, But all are replacement numbers not original. The prices on these items are close to extortion Based on the guidance and info supplied by your membership I don' see the rewiring of the box as an insurmountable problem. Substitutions were mentioned in some replies and any other parts source info would be great. If anyone knows of an alternate method of controlling this Gen. I would be very interested This Generator was purchased to replace a propane unit that proved to be intolerably expensive to fuel for anything but short outages and living where we do there are many. This DJB gen. set is not only desirable its really needed.
Regards Jim
Name:	control box 10-15-14 003.jpg
ID:	209171   Click image for larger version
Name:	control box 10-15-14 006.jpg
ID:	209173   Click image for larger version
Name:	control box 10-15-14 007.jpg
ID:	209175   Click image for larger version
Name:	control box 10-15-14 012.jpg
Old 10-22-2014, 11:56:45 AM
JohnnyC JohnnyC is offline
I see you are in Budd Lake, NJ which is about 30 minutes away from me. I am in the Boonton/Montville area. If you decide it is out of your scope to fix the 6K DJB for whatever reasons and want to sell it at a reasonable price, let me know.
JohnnyC
New Jersey
Old 10-22-2014, 12:24:53 PM
Keeper if I were you I would keep this machine. Take you time and refurbish those relays, etc., to the extent possible. Remove the generator end bell cover and look over the magneciter coils. If they show no signs of over heating, them you may have a diamond in the rough.
If you refurbish this DJB, you will have something that no present day small generator can compete with. This thing can run 24/7@ FL. for a long long time.
You said it was running (recently???) In that condition with all that rust inside the control box?
Worst case, you can sell it for parts and I am sure recoup what you paid for it. Just those Onan meters themselves are worth more than you think. I bought mine new from Onan back in 1970 and I think I paid about $50 each.
Can you show us a few more pictures of the DJB condition? You are in the right place for help and advice.
Old 10-22-2014, 01:26:10 PM
Isaac-1 Isaac-1 is offline
As an alternative you could replace the the contents of most / all of the control box with a modern integrated retrofit controller like this one from flight systems http://www.flightsystems.com/standby...e-control.html
(this may stilll require a couple of external relays depending on application)
There are other cheaper options out there, like the Deep Sea controller clones on ebay, etc.
The Following User Says Thank You to Isaac-1 For This Post:
Onan 5.0rv bga need to replace carburator pello38 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-14-2014 07:46:42 PM
rebuild or replace Prestolite Starter Tim0477 Onan Generators 8 02-21-2014 08:15:22 PM
Onan 12.5JC - Fixup or replace? farokh Onan Generators 107 01-11-2013 09:16:40 PM
To Rebuild or Replace Ford 9N engine... That is the Question? wxyoung2008 Antique Farm Tractors 15 11-05-2011 10:01:05 AM
Onan Help-replace or not? steve tyson Onan Generators 1 01-11-2003 10:28:37 AM
