Onan 6k DJB Controller Rebuild/Replace
this thread has 41 replies and has been viewed 4137 times
Old 11-01-2014, 08:17:31 PM
Kpack
Default Re: onan 6k DJB controller rebuild/replace
98.3 % he doesn't need his temperature Jim.
Old 11-02-2014, 01:11:12 AM
jrad235 jrad235 is offline
"Damn it, man, I'm a doctor, not a torpedo technician!"
Sorry, couldn't help the Star Trek reference. Great thread guys!
Old 08-24-2015, 09:19:35 PM
Buckrog773 Buckrog773 is offline
[QUOTE=keeper;1100627]Hello
Just an update on the DJB .I decided after being encouraged by the posts on these boards to go ahead and completely restore the controller. It took some time but I managed to acquire all the components I needed which included all four of the rusted relays ,the rectifier ,resistors and the switches. I cleaned up the Emg (lop) relay, the internals were clean and everything seems in order but, I'm concerned about the corrosion of the heating element . The relay is a 320a104 with a circuit board attached containing a micro switch ,which apparently is only used to send a remote alarm. I have to test the thing someow . I don't want it to come back and bite me if the coil fails .Any help or advice here is welcomed. The deeper I get into this machine the more I come to appreciate it's quality. They really don't make anything like this anymore. I managed to mouse proof the housing with the 1/4 inch screening as was suggested .The sheets provided by Doug proved especially helpful as was all the advice and help provided on the posts .There is a lot of work here but I'm having a little fun too. Thanks to all. Jim[Keeper- I'm wondering where you found all of the components for your controller rebuild? Were you able to find original Onan or did you go with something else? As you can see from the pictures I have the same problem. Thank you. Model # 6.0 Djb-18r/16654aa Serial # L75 099 1810]
Old 08-24-2015, 09:33:03 PM
Billy J Shafer's Avatar
The board on back of the 104. Is for remote alarm. Not needed unless you want a remote alarm. Just use the main section.
Old 08-24-2015, 09:53:34 PM
[QUOTE=Buckrog773;1195734]
Originally Posted by keeper View Post
Hello
Old 08-25-2015, 02:18:11 PM
[I don't think I posted my question for "Keeper" correctly above - I'm wondering where he found all of the components for his controller rebuild? Was he able to find original Onan parts or did you go with something else? As you can see from the pictures I have the same problem. Thank you. Model # 6.0 Djb-18r/16654aa Serial # L75 099 1810]
Old 08-25-2015, 02:37:46 PM
Detest MICE!!!! To pieces.
Old 08-25-2015, 04:08:19 PM
BigBlockChev's Avatar
Thats like something from the rodent version of Better Homes and Gardens.
Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
  #29
Old 08-25-2015, 05:01:36 PM
len k len k is offline
We were talking about your DJB in http://www.smokstak.com/forum/showthread.php?t=148676 Couldn't read serial number from pics that well, looks like I was off one digit on serial number so the build sheets in this link are likely wrong.
Was the injector pump attached?
Think I'ld start by checking the windings for cuts from mice , before I spend money on anything else.
Check winding resistances for opens.
Should be able to by-pass all the controls for a test run. When engine runs keep the sheet metal on it , it directs cooling air over engine fins. There likely is a performance test where you can disconnect AC voltage reg and energize field with fixed DC voltage, run engine and check output voltages. That's how you check the $$$$ windings in Onan NHE types.
Old 08-25-2015, 07:10:44 PM
I have been replacing the "open relays" with plug in relays & bases from Allied Electronics. I do not have a "D"J set (yet), but I think they have 1 more relay or maybe switch for the glow plugs.
Do a search here for "Allied Electronics", I think I have posted numbers for relays & bases several times. Be aware that one of the relays has a 6V coil on it.
I found the numbers in my files, attached below. You can also find the start / stop switch, pre-heat switch as well as terminal strips here all for a fraction of OEM parts. http://www.smokstak.com/forum/album....pictureid=4354 a picture of a converted JC (not DJC) control box can be found here, as well as "before" pictures.
ALLIED ELECTRONICS
7151 JACK NEWELL BLVD. S
FT WORTH, TX 76118
800-433-5700
WWW.alliedelec.com
6 volt relay
Mfg. # LY2-DC6
ALLIED STK # 798-1007
12 volt relay
Mfg. # LY2-DC12
ALLIED STK # 834-1168
Relay socket
Mfg. # PTF08A-E
ALLIED STK # 834-1408
The Following User Says Thank You to Max Thompson For This Post:
Onan 5.0rv bga need to replace carburator pello38 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-14-2014 07:46:42 PM
rebuild or replace Prestolite Starter Tim0477 Onan Generators 8 02-21-2014 08:15:22 PM
Onan 12.5JC - Fixup or replace? farokh Onan Generators 107 01-11-2013 09:16:40 PM
To Rebuild or Replace Ford 9N engine... That is the Question? wxyoung2008 Antique Farm Tractors 15 11-05-2011 10:01:05 AM
Onan Help-replace or not? steve tyson Onan Generators 1 01-11-2003 10:28:37 AM
