Onan 6k DJB Controller Rebuild/Replace
this thread has 41 replies and has been viewed 4496 times
Old 08-25-2015, 09:12:14 PM
len k len k is offline
Default Re: onan 6k DJB controller rebuild/replace
I like sealed relays, less chance of junk getting in contacts and sticking up pivot assembles
Old 08-25-2015, 10:20:11 PM
Buckrog773 Buckrog773 is offline
Thanks for the replys and advice everyone, I have some research and work to do.
Max - your replacement pictures/ project look great!
Ken- yes the injection pump is there.
Old 08-25-2015, 11:13:16 PM
I'm guessing it has low hours from the look of it , but all diesels can run on just the crankcase oil if rings are bad, called runaway. Usually damages engine. So have a way to stop air flow into intake if it decides to runaway, that's the only way to stop it, short of maybe discharging a BIG tank of CO2 into intake.
I've heard of people using a book or plywood. Forget about rags, people say it will just suck them in and blow flaming oily rags out the exhaust.
Old 03-22-2018, 04:19:54 PM
keeper keeper is offline
Hello Johnny C
Posted thread. Keeper
Old 03-22-2018, 04:50:11 PM
JohnnyC JohnnyC is online now
Originally Posted by keeper View Post
Hello Johnny C
Okay Keeper - Nice to talk with you on the phone. Let me bring the group up to date on this thread especially since it started in 2014.
Update: Today while looking through Craigslist I spotted the following ad
https://newjersey.craigslist.org/grd/6536211059.html . Since this ad is local to me, I responded. Emails then a phone call resulted only to find out the seller (Keeper) posted here 4 years ago.
Long story short, Keeper did a restore, had it tested at a generator shop in the local area, put it away for a while and later found out mice made the control box their home. Everything got pee'd on (typical for J series control boxes). Keeper replaced everything in the control box, but it never ran afterwards. When he attempted to start the DJB, it only made clicking sounds. He checked to ensure that the motor was not locked up. At that point he wants to sell as he feels it is beyond his capability to fix it, but he really wants to fix it to work again.
I took a quick look at the 4 pages in this thread and discussed a few things with keeper over the phone. After the mouse piss destruction, the original starter solenoids were replaced with off the shelf automotive solenoids, not Onan replacement solenoids . See a possible problem here....
I suggested to Keeper to revive this thread and let's help Keeper to get his DJB running again since that is really what he wants.
Keeper, if you can, please take good clear pictures of the inside of the control box as it look today.
JohnnyC
New Jersey
The Following 3 Users Say Thank You to JohnnyC For This Post:
  #36
Old 03-22-2018, 05:44:57 PM
consolenut consolenut is offline
Default Re: Onan 6k DJB Controller Rebuild/Replace
Nice machine. Im sure youll get it running again in no time. Nice paint job!
Old 03-22-2018, 07:43:27 PM
HBSaunders HBSaunders is offline
Only on smokstak can a devoted bunch of talented membership pay tribute to an example of great American craftsmanship such as the Onans. Let's make Onans great again!
Old 03-22-2018, 07:52:41 PM
I would like to focus on the solenoids in the control box to help Keeper... I don't have a parts manual or looked for one yet, but Keeper replaced the solenoids with off the shelf automotive solenoids and I'm guessing like the Ford solenoids. These solenoids replaced the Onan OEM solenoids. We all know that in the RV gensets, standard automotive solenoids will not work. I assume the same would apply to Keeper's DJB. What would be the results if the solenoid is the incorrect type when trying to start the genset? Keeper stated that he only hears clicks and that is all when trying to start the DJB. I always replaced OEM with OEM so I would not know.
JohnnyC
New Jersey
Old 03-22-2018, 09:50:48 PM
RETCPO RETCPO is offline
Here is what I done to a 5 CCK that the previous owner replaced the solenoid with a Ford.
Replace the FORD solenoid with a NAPA ST71 with isolated coil.
Wired per instructions (jumper wire from battery side to one small terminal other small terminal receives ONAN start wire)
The Following User Says Thank You to RETCPO For This Post:
  #40
Old 03-26-2018, 03:51:08 PM
Johnny C,
See attached photos. The generator got pretty dirty.
ID:	306660   Click image for larger version
ID:	306661   Click image for larger version
ID:	306662   Click image for larger version
Onan 5.0rv bga need to replace carburator pello38 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-14-2014 07:46:42 PM
rebuild or replace Prestolite Starter Tim0477 Onan Generators 8 02-21-2014 08:15:22 PM
Onan 12.5JC - Fixup or replace? farokh Onan Generators 107 01-11-2013 09:16:40 PM
To Rebuild or Replace Ford 9N engine... That is the Question? wxyoung2008 Antique Farm Tractors 15 11-05-2011 10:01:05 AM
Onan Help-replace or not? steve tyson Onan Generators 1 01-11-2003 10:28:37 AM
