Onan 6k DJB Controller Rebuild/Replace
this thread has 41 replies and has been viewed 4456 times
Old 03-26-2018, 05:00:28 PM
Vanman Vanman is offline
Default Re: Onan 6k DJB Controller Rebuild/Replace
If Onan controller grounds the line to the solenoid coil, and Ford solenoid has a grounded coil to start with, nothing would happen. You'd hear the click of the other control relay(s), but the cranking solenoid would never pull in.
Old 04-12-2018, 10:22:24 AM
Cav Cav is offline
Default Re: onan 6k DJB controller rebuild/replace
Mine wasn't as bad as yours, but I did have to replace the relay in your picture 006. I used the following part. The relay manages all the safety switches. You Don't have to use this one, I just happened to have it. This one has one or two extra contacts you don't use.
https://www.digikey.com/product-deta...PB173-ND/45038
Onan 5.0rv bga need to replace carburator pello38 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-14-2014 07:46:42 PM
rebuild or replace Prestolite Starter Tim0477 Onan Generators 8 02-21-2014 08:15:22 PM
Onan 12.5JC - Fixup or replace? farokh Onan Generators 107 01-11-2013 09:16:40 PM
To Rebuild or Replace Ford 9N engine... That is the Question? wxyoung2008 Antique Farm Tractors 15 11-05-2011 10:01:05 AM
Onan Help-replace or not? steve tyson Onan Generators 1 01-11-2003 10:28:37 AM
