Onan 4.0BFA IR/ 160 120 Carb Kit
this thread has 9 replies and has been viewed 899 times
Old 03-02-2017, 10:05:33 AM
benraines304 benraines304 is offline
Default Onan 4.0BFA IR/ 160 120 Carb Kit
I'm looking for a carb kit for this walbro carburetor that has come off an old Onan 4.0BFA Generator.
I can't seem to find a model number for the carb anywhere.
I can attach another pic if needed.
Any input or pointing in the right direction is appreciated..
Name:	2017-02-26 15.48.11.jpg
ID:	276311   Click image for larger version
Name:	2017-02-26 15.49.00.jpg
Old 03-02-2017, 10:47:35 AM
Kevin K Kevin K is offline
Default Re: Onan 4.0BFA IR/ 160 120 Carb kit
It looks like a Walbro LUA carburetor used on some Onan BFA and BGA generators.
Old 03-02-2017, 10:51:22 AM
Great.. Thats what I was thinking to.... the LUA threw me off....
I wish they'd label these carbs better...
Thanks again
Old 03-02-2017, 10:58:47 AM
LRomero LRomero is offline
When you pull the top cover off, can you take a picture of the carburetor for me? In particular, there is a small screw toward the top of the carburetor directly above the points box. I'm trying to see how that is setup, because both LUA carburetors I have on a BFA and NH have been tampered with.
Old 03-05-2017, 08:40:02 PM
Hope these pics help....
Name:	2017-03-05 14.27.46.jpg
ID:	276625   Click image for larger version
Name:	2017-03-05 14.27.51.jpg
Old 03-05-2017, 09:06:03 PM
This does help, thanks!
In the picture I attached, can you get a better picture of this area? Also a picture of the outside of the carburetor where this but is?
Is this screw bottomed out on yours or is there room to thread in?
Old 04-09-2018, 10:54:09 PM
Dennis112885 Dennis112885 is offline
Did you ever figure this out? I'm wondering the same thing.
Old 04-10-2018, 02:54:11 PM
consolenut consolenut is offline
Default Re: Onan 4.0BFA IR/ 160 120 Carb Kit
Just clean the carb and the needles with carb cleaner and air. Most time don't need a rebuild kit. Ive taken apart and cleaned half dozen of those carbs. All run like new. 2 cans of carb cleaner per carb but there clean
Old 04-10-2018, 09:44:38 PM
I cleaned my carb. I'm going to do it again. I lost the float spring so I bought a rebuild kit.
What I'm asking about is the plug/set screw that screws into the carb. LRomero circled it in a picture he attached and I attached a diagram with a red arrow pointing to where it is installed. What I want to know is if this set screw should be screwed all of the way in. There is a jet that it butts up to if it is screwed in completely, blocking off the jet. Looking at the parts diagram, there is normally a plug. It shows an option for a variable jet kit which has a set screw.
Name:	Screen Shot 2018-04-10 at 9.34.33 PM.png
Old 04-14-2018, 09:20:33 PM
In case anyone else has this issue, I had to screw the set screw all of the way in for the engine to run.
The Following User Says Thank You to Dennis112885 For This Post:
Onan 4.0BFA-1R/16004C oregonfarmboy Onan Generators 12 07-31-2015 08:53:53 AM
Onan 4.0bfa-1r/16004c Onan Dan Onan Generators 13 06-20-2014 12:15:21 PM
Onan 4.0BFA-1R new guy PatL Onan Generators 8 05-09-2013 06:23:06 AM
Carb.problems on 4.0BFA,Please Help!! 69zfarmer Onan Generators 1 01-06-2007 09:24:22 AM
