Onan 2LK (experimental model) Has Come to Life!
this thread has 701 replies and has been viewed 23691 times
Old 04-16-2018, 11:22:41 PM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: Onan 2LK (experimental model) Has Come to Life!
Originally Posted by vanman View Post
what is the rpm on that little guy?
2000-2600 rpm.
The Following User Says Thank You to OnanParts For This Post:
Old 04-17-2018, 06:27:14 PM
Mariner Mariner is offline
Originally Posted by OnanParts View Post
This little 12V 50AMP 0.6 AK feels left out....... He is from the "K" family.....
Those charging units are pretty neat. I imagine they would serve an off grid cabin well charging batteries and powering a few lights.
Old 04-17-2018, 09:17:21 PM
Johnny,
If switch the remote/manual switch up to the remote setting on your LK, does your ammeter read about 7 amps?
Old 04-17-2018, 09:44:52 PM
JohnnyC JohnnyC is offline
Originally Posted by Mariner View Post
Johnny,
My amp meter will show a discharge (swings to the left of center) when flipping to manual. I do not remember how much of a downward swing was shown, but it was very noticeable. I was not sure if that is normal. I assumed the discharge was due to supplying power to the coil, but I may be wrong. I can check tomorrow and post back exactly what the meter reads when flipping to manual if you want.
JohnnyC
New Jersey
  #595
Old 04-17-2018, 09:54:44 PM
Thanks I would appreciate that....
Old 04-17-2018, 10:29:59 PM
No problem. I will check it out tomorrow after work and post back in the evening. One thing I want to clarify is that the amp meter will show a discharge when immediately flipping the switch to manual. I have no clue what would happen if I tried to manually start the LK using a rope, but I would assume it would operate as normal and show a charge. I am Tooooooo Lazyyyyyyy to manually start anything that has electric start
JohnnyC
New Jersey
Old 04-18-2018, 09:31:05 PM
Johnny,
The results: If I flip the switch to manual and rotate the crank, the amp meter will show a discharge of 5 amps depending in the rotational position of the cranks shaft. I hope this helps.
Does your amp meter show a discharge when the switch is in manual? If so, will is show a constant discharge while rotating the crankshaft?
JohnnyC
New Jersey
  #598
Old 04-19-2018, 12:49:35 PM
Thanks for the update Johnny. Attached is what I'm faced with on the ammeter.
1st picture in the meter in manual mode (top center) if i select remote and then back to manual it will fire the coil. ( engine not running)
2nd pic is the meter in the remote setting ( notice the reading on the meter showing juice from the battery (engine not running)
3rd picture disregard it's a duplicate of 2
4th picture is with the engine running (shows a negative reading)
If I turn the flywheel by hand in manual mode the meter will bounce to the right.
If I leave the switch in the remote setting it will kill the battery in 24 hours. Also, I can only turn the unit off if its in manual mode, I think that's how it was set up. Not sure on the battery drainage issue though. Is your LK setup this way?
If I pull the positive wire from the left post of the meter, this is the one that is connected to the reverse current relay, the meter will run towards the right showing a positive charge while engine is running. I must have something wired wrong but I can't figure it out. I may have to make a video of the issue with some shots of the control box. What are your thoughts?
ID:	308621   Click image for larger version
ID:	308622   Click image for larger version
ID:	308623   Click image for larger version
Old 04-19-2018, 01:32:44 PM
Vanman Vanman is offline
It looks to me like the wires on your meter are reversed. Showing charging with it not running, and discharge when it is running.
There are obviously other problems as well, since it discharges the battery when it shouldn't.
Sounds like someone thought that they were smarter than they actually are. Went in there and mucked it all up.
The Following 2 Users Say Thank You to Vanman For This Post:
  #600
Old 04-19-2018, 01:53:48 PM
When I got the set the previous owner had put a push/pull on off switch on the control box cover. I'm thinking he didnt know how to shut it down and figured something was wrong so he added the switch. Looking at the wiring diagram everything looks correct, but I'm more mechanicly than electrically inclined. It is a new gauge but it's the same model as the old one. I do agree with you that it seems something is crossed.
Model 31 washer back to life Dustin D Ehli Maytag Engine Collectibles 1 10-09-2016 08:51:27 PM
Another Model Callahan Cam Stopper Comes to Life Gil Garceau Scale Model Engineering 11 06-06-2014 06:01:59 AM
economy model s back to life Tim Rostar Antique Gas Engine Discussion 1 09-29-2012 09:09:09 PM
Lehmann M1867 model is back to life stirlingmaier Hot Air Engines 5 03-18-2011 03:29:22 PM
Experimental Model 31 Maytag MaytagRepairMan Maytag Engine Collectibles 12 12-21-2010 08:03:07 PM
