Onan 7.5 kw Ignition Problem
this thread has 27 replies and has been viewed 1567 times
Old 03-13-2018, 09:04:28 AM
Steelhant Steelhant is offline
Default Onan 7.5 kw Ignition Problem
Hello. I have this unit for at least 35 years have it in an enclosure that forced me to take of the info plate...and now I have know idea where I placed it..
The unit when it runs, runs perfect, I start it manually. I know it was 3 phase but I only use two and it runs on natural gas. I have ordered points several times from Cummins in the NE, thats all I really had to change.
Over the years there had been times when it ran for a week plus, then died, new points and it runs perfect again. Same thing this past week, ran for three days then died....But its a great machine when it runs.
Question I have is there anything I could do different to get the points to last longer ?
I really like this unit, quiet and work perfect for what I need, ignition been the only problem.
Thank You,
Chuck
Old 03-13-2018, 10:01:39 AM
Default Re: Onan 7.5 kw ignition problem
Do the condenser also!
Old 03-13-2018, 10:33:56 AM
EnginePat EnginePat is online now
Condensor! ! Go to napa auto parts for the points and condenser, change both condensor and points at the same time, bad condensor = burnt out points!
Check out #6 on this thread for the part numbers.
https://www.smokstak.com/forum/showthread.php?t=150829
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 03-13-2018, 04:12:54 PM
Might consider "Kirk Engines points saver". They are used by several here at The Stak and I have heard nothing but good about the device.
Pretty sure Onan did make an electronic ignition trigger set up for the JB, it is possible it was an after market item, but I do not think so. I have 4 sets that have this on them. The trigger mounts in the end bell of the generator.
The Following User Says Thank You to Max Thompson For This Post:
Old 03-13-2018, 04:25:43 PM
len k len k is online now
Post a pic of the gen. I'm assuming you have a JB , but there are other models out there.
As far as other types of ignition see my thread
https://www.smokstak.com/forum/showthread.php?t=167037
In particular ~ 2/3 way down this link http://gardentractorpullingtips.com/ignition.htm
Old 03-13-2018, 07:22:04 PM
dracer dracer is online now
plus one on the kirk engines ,works very well if you start with new points you will probability will never have to replace again
Old 03-13-2018, 11:32:17 PM
Default Re: Onan 7.5 kw Ignition Problem
Thank you very much for all this info...I have some reading to do.
I will post a few photos tomorrow.
Thank Again,
Chuck
Old 03-14-2018, 09:15:44 AM
Leon N. Leon N. is offline
When you install the new condenser adjacent to the points, L believe it is a 3 mmf condenser. Make sure you get the correct one installed and retire the eninge using the engine-stopped procedure as described in 967-500.
Once you get it running, observe the points to make sure there is NO sparking as the point open.
Old 03-14-2018, 11:37:52 AM
Here are a few photos, I have a new set of point, just have to get new condenser. Also waiting on info on points saver.
Thank You,
Chuck
ID:	305535   Click image for larger version
ID:	305537   Click image for larger version
Old 03-14-2018, 11:41:32 AM
Not sure what you are referring too. "engine-stopped procedure as described in 967-500"
Thank You,
Chuck
need assistance in diagnosing Onan ignition problem AndersonMillTexas Onan Generators 48 03-05-2013 07:35:30 PM
ONAN 4KYFA26100G Ignition problem brwsheridan Onan Generators 1 09-12-2012 08:49:51 AM
Help with Onan ignition problem CIECO Onan Generators 14 10-29-2008 01:02:03 PM
Ignition problem on EK SteveSchantz Magnetos, Ignition Coils and Spark Plugs 3 09-05-2008 12:07:32 PM
JD MT ignition problem M.Smith Antique Engine Archives 4 07-25-2004 08:55:43 PM
