Onan 15.0JC-18R Control Box with Extra Relays
this thread has 28 replies and has been viewed 1249 times
Old 04-10-2018, 07:22:11 AM
widlin1 widlin1 is offline
Default Onan 15.0JC-18R Control Box with Extra Relays
I just picked up the following electric plant
Model: Onan 15.0JC-18R/11917AA, serial number 1174884620
I am looking for a higher resolution scan of the wiring diagram for the control box and ignition than what is in the documents library. I want to put the wiring back to its original configuration, see below.
History: I was told it came out of a school it was set up for natural gas or LP and then migrated (no regulator with it) and sat from home garage to home garage to most recently my garage. I took the sheet metal off, pulled the plugs, put a little marvels in each cylinder before turning over by hand. Its turns freely with no plugs in and feels like it has good compression with the plugs in. The control box had a pile of sunflower seed hulls but no chewed wires and probably some dried urine. There were also two ice cube relays and a third single pole single throw relay along with a maze of wires connecting them ultimately to two wires which came out of the box. I figure they are for the fuel shut off valve. The centrifugal switch was adjusted closed, I set it to a 0.02 gap and verified that the points have the same gap. Something is stopping voltage going to the coil, unless I hold the single pole, single through relay closed by hand (this is with an empty relay connected to the two external wires, if I short those wires all the relays in the box close). I don’t think I tried starting it while holding the relay closed.
I did start the generator by jumping a hot wire to the coil and using a spray can of throttle body cleaner to run it for five or six seconds so I know it will start and run if I solve the power to the coil problem. I believe that putting the wiring back to the original configuration will either solve the problem or allow me to figure out what component was bypassed by the extra relays, if that is why they were in the box.
Any help/comments would be appreciated.
Jeff
Old 04-10-2018, 07:51:50 AM
Default Re: Onan
A picture of the inside of the box showing the relays would be a big help. We may be able to tell what is OEM and if something has been added.
Old 04-10-2018, 08:16:41 AM
MBB MBB is offline
Default Re: Onan 15.0JC-18R control box with extra relays
Here is your build sheet and a copy of the wiring diagram. Hope its better.
By the way welcome to the Stak. Your Centrifugal switch should be I believe .020 .02 would be quite small. I assume you got the manuals?
Old 04-10-2018, 08:37:58 AM
This is the only picture I have on my phone, Since taking it I have moved the extra relays outside the box and cleaned the contacts on the s12 relay which you can see are dirty/urine covered on their exterior.
[URL=Caution-http://s461.photobucket.com/user/Widlin1a/media/14500.jpeg.html][IMG]Caution-http://i461.photobucket.com/albums/qq335/Widlin1a/14500.jpeg[/IMG][/URL < Caution-http://s461.photobucket.com/user/Widlin1a/media/14500.jpeg.html][IMG]Caution-http://i461.photobucket.com/albums/qq335/Widlin1a/14500.jpeg[/IMG][/URL > ]
Sorry about the bad link for the pic. I will have to figure that out when I get home this afternoon. If you like I can e-mail it directly to you before then.
MBB, that is a much better image.
Thank you for both files.
Jeff
Old 04-10-2018, 08:44:07 AM
Billy J Shafer's Avatar
Gap should be .020 on both.
Old 04-10-2018, 09:18:52 AM
Thank you, both are set to 0.020 inch.
Jeff
Old 04-10-2018, 09:31:06 AM
grif grif is offline
I wonder what the difference is between .02 and .020
The Following 3 Users Say Thank You to grif For This Post:
Old 04-10-2018, 09:36:11 AM
Dale Russell Dale Russell is offline
They are the same. He just left off the last zero. Common knowledge to a Machinist.
Old 04-10-2018, 10:02:31 AM
Default Re: Onan 15.0JC-18R Control Box with Extra Relays
I agree some might know. But most would see .02 and try to set it at that. That is why we must post things that the common person can understand.
Old 04-10-2018, 11:14:56 AM
Pauls12 Pauls12 is offline
I agree, Billy. I would have called it two thousands. Thanks!!
The Following User Says Thank You to Pauls12 For This Post:
Onan 15.0 MDJF - need help sourcing relays... nukeguy Onan Generators 22 02-26-2016 05:07:53 PM
Onan 4.0BGE-3CR/28202E - two external relays? megavolt512 Onan Generators 12 02-02-2016 08:20:53 PM
onan nh w/ 859 board to relays swap YellowLister Onan Generators 2 05-10-2015 01:44:57 PM
Onan 5.0CCK extra oil tank David C Onan Generators 4 10-15-2012 10:52:10 AM
