No Start When Cold
this thread has 14 replies and has been viewed 703 times
Old 04-11-2018, 11:00:31 PM
Zeromedic Zeromedic is offline
Default Re: No Start When Cold
There isn't any thermostatic switch on that genset.
The prime solenoid is connected directly across the start solenoid.
A little is good. Any more is too much.
Old 04-12-2018, 10:43:04 PM
Gatorgetter Gatorgetter is offline
Thanks for the reply. This is my understanding please correct me if I'm wrong. When the solenoid goes in it gives it more fuel . So on a cold start it doesn't need as much fuel because the air is denser. And if the solenoid engages I'm flooding out. So screwing out the red knob should improve my situation
Old 04-13-2018, 12:11:07 AM
Motorhead's Avatar
Originally Posted by Gatorgetter View Post
This is my understanding please correct me if I'm wrong. When the solenoid goes in it gives it more fuel . So screwing out the red knob should improve my situation
YES to both questions.
Are you sure this regulator came originally with your generator?
My 1939 WILLYS Pickup.
Bought in 1971
Old 04-13-2018, 06:46:14 AM
The gen has 150hrs looks bone stock, I wouldn't think it's something, that's been changed or added
Old 04-13-2018, 11:44:20 AM
Motorhead's Avatar
Does your generator have a remote switch inside a camper or trailer? If so, I know on at least the gasoline models of your style of set, you would push the STOP button BEFORE starting and it would prime the gasoline system. Look at your regulator primer button and have someone push the stop button on the remote. See if the solenoid engages. You might just want to disconnect it and if you need to prime the system, just push the button manually.
Bought in 1971
Perkins Cold Start Greg Moore Kohler Generators 15 01-01-2016 11:16:06 AM
DKAC cold start Jim Marcozzi Onan Generators 2 08-29-2015 04:36:46 PM
old Onan start cold start L Nice Onan Generators 1 02-12-2012 05:13:50 PM
Cold start and update Aevry Small Air Cooled Gasoline Engines 3 05-18-2011 09:02:53 AM
Cold start fluid for GM 3-71 Manorfarmdenton Antique Farm Tractors 12 03-11-2010 02:43:57 PM
