1977-78 Onan 4kw Fires Only When Holding Switch
this thread has 12 replies and has been viewed 612 times
Old 04-13-2018, 01:05:48 PM
Kevin K Kevin K is offline
Default Re: 1977-78 Onan 4kw Fires Only When Holding Switch
Do you have a BF or BFA?
BFA Parts book 965-0222 part # 353-0057 3.4 ohms 25 watt
BF parts book 965-0220 Part # 353-0057 3.4 ohms 75 watt
One of those wattages may be a misprint.
Old 04-13-2018, 08:00:03 PM
wmrayt wmrayt is offline
the only ones I have been able to find are 25 watt. I have ordered several and the diode rectifier also.
Old 04-18-2018, 07:57:42 PM
Up Date:
I took the side case off of the motor and got the ID plate under a well lit magnifying glass it is a 4.0 BF-3C/16000B.
I ordered the resistor that is under the generator cover and replaced it.
IT'S ALIVE!!!!!!!!!
It will not handle much of a load yet before it kills it but getting a little better every day. Hope it will handle the fridge and a/c together.
I have another question though.
When running the generator going down the road will it mess with the charging from the alternator?
The Following User Says Thank You to wmrayt For This Post:
Onan RDJC 1977 coinbalt69 Onan Generators 11 10-05-2017 10:38:42 PM
Onan 4.0 BGE-FA only fires when start switch pressed sopicki Onan Generators 11 04-29-2017 11:40:15 AM
ONAN 6.3 NHOFB only runs holding starter button. rpmalerba Onan Generators 88 08-03-2014 10:56:52 PM
Onan 6.5 NH 1977 Start Switch stopped working bodyboard Onan Generators 7 12-17-2012 09:34:30 PM
help onan won't run without holding start button and not charging wendyjwalks Onan Generators 6 06-26-2012 11:52:25 PM
