Is this an Onan?
this thread has 7 replies and has been viewed 455 times
Old 04-16-2018, 09:45:44 PM
JohnnyC JohnnyC is offline
Default Is this an Onan?
Is this an Onan (see picture below)? I do not recognize the model, but it is painted Onan green
JohnnyC
New Jersey
Old 04-16-2018, 09:53:10 PM
Billy J Shafer's Avatar
Default Re: Is this an Onan?
Looks like the APU for the B17 up to the B36. Plus some military equipment.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 04-16-2018, 09:55:33 PM
I think that is a 2 stroke Homelite.
The Following 4 Users Say Thank You to Wayne 440 For This Post:
Old 04-16-2018, 09:56:29 PM
Troll's Avatar
Troll Troll is offline
JohnnyC
New Jersey
Homelite. I have one just like it for my water truck:
The Following User Says Thank You to Troll For This Post:
Old 04-16-2018, 10:39:23 PM
Vanman Vanman is offline
Yep, I have one of those Homelites too. 3600 rpm two stroke. Quite the buzz!
Old 04-16-2018, 10:42:08 PM
Ben Cowan Ben Cowan is offline
I had several of these old military genders they were two cycle. Mine put out 32 volts and we’re used primarily for starting old planes as Billy stated. The units were sold locally after airbase closed. Many made their home on remote fishing cabins until cheap and quiet 120 volt generators appeared. I finally scrapped mine. Bulbs were just too high to justify! Luck to all, Ben
The Following User Says Thank You to Ben Cowan For This Post:
Old 04-17-2018, 10:59:34 AM
Tracy T Tracy T is offline
that's a homelite two stroke noisy as hell and loved fuel. I had one and gave it away!
Old 04-17-2018, 12:32:04 PM
Exclamation Re: Is this an Onan?
There should be an instruction plate somewhere. It will tell you oiling instructions and voltage output. Should have S/N on it too. Oiling instructions may be on the fuel tank cap too. I believe they were 20:1, and you can use modern 2 stroke oil in them. They are noisy, race at 3600 RPM, and are very reliable. Only one fault that I know of: the bearing in the governor - point assembly goes bad and allows the magnets in the flywheel to hit the armature on the mag, magnetizing it. Then you won't get spark. Use 16:1 in it, the bearing won't wear out. Nice looking unit. Need help with it, I am in rockaway. Let me know!
