Onan DJB Genset - Just Purchased
this thread has 26 replies and has been viewed 4247 times
Old 03-28-2011, 06:13:46 PM
Default Re: Onan DJB Genset - Just Purchased
Leon:
I offered James a copy of the 967-500 manual because it has the magniciter wiring diagrams for the J series, although it does not have wiring diagrams for the diesel engine, I think it would be good for him to have. I do not have a DJB engine service manual to send him. (967-500 is 3.7 meg. it usually e-mails fine)
James:
As Leon noted, the Onan manuals are black & white, save for a few colored covers. If you will post an e-mail address we will send you what we have, there is no charge for this, though you may feel free to send Harry a donation to help continue this great forum he provides for us.
The Following 2 Users Say Thank You to Max Thompson For This Post:
Old 03-28-2011, 09:44:20 PM
Leon N. Leon N. is offline
Max:
You are 100% correct. 967-500 covers only the JB and JC versions not the DJB or the DJC versions. However, my Onan color brochure does illustrate both the gas-gasoline and diesel designs, with an excellent write up with schematics of the Magneciter end.
Just curious, why would anyone want to replace the Magneciter saturable reactors with an electronic voltage requlator and at the same time loose the robustness of the alternator.
Leon
Old 03-28-2011, 09:57:23 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan DJB Genset - Just Purchased
What you want is Onan #967-0301, #967-0751
Bruce in alaska
Old 03-28-2011, 11:32:16 PM
Isaac-1 Isaac-1 is offline
Leon, have you priced Magneciter parts lately?
Ike
Old 03-29-2011, 08:48:39 AM
Isaac-1
No, but I see what you mean. I cannot imagine a magneciter failing unless of course it was abused. I would rewind a coil if necessary or merely replace the diodes. That's all there is to it.
Leon
Old 03-31-2011, 11:59:34 AM
keeper keeper is offline
Good Morning all;
I have been busy gathering manuals for my DJB vintage 11/1972 Genset. The 967-0751manual I have covers the engine. BTPost made reference to Manual 967-0301. This manual has so far eluded me. Any guidance or help in acquiring it would be great
Thanks for all the help, keeper
Old 03-31-2011, 01:01:15 PM
BTPost's Avatar
Images: 1
send me an eMail address, via PM and I'll see if I can help you out...
Bruce in alaska
Old 04-05-2011, 07:33:04 PM
Good evening;
Some progress here,and also a few questions. The genset was gunked and cleaned ,and all the sheet steel from the housing is being repaired, primed, painted. Got a near perfect paint match at sherwin williams. The fuel injection pipes are in sad shape completely rusted and crusty. I priced out replacements $ 365 plus ship @ tax (6 parts).A question I have is can these be fabricated . Tools are available @ Jeggs & Mc Masters. My thought is to buy other much less expensive pre-formed tubes and rework them to fit. Manual 967-301 for Rev. R and later shows a different routing for the injection tubing than my engine ( 6.0 DJB 3R / 12482S ). A little puzzleing. Has anyone out there been this route before. Does not seem to be much on the posts. Flange type angle, tube size, and material are a few things buzzing around my head. Photos will be posted as soon as I can get my computer returned to normal. Hard drive had to be replaced. As always any and all help is very much appreciated.
Thanks again , Keeper
Old 04-05-2011, 08:10:51 PM
K D Redd K D Redd is offline
You know that Fuel Injector Lines on a diesel engine MUST be the same length to ALL cylinders.
Kent
The Following 2 Users Say Thank You to K D Redd For This Post:
Old 04-06-2011, 01:32:03 AM
If they're not leaking, I would clean up and install them and then paint in place once you get it running. The wall of the lines is very thick, so some rust would likely not be a problem. You should be able to find a used set somewhere.
I have a Ford diesel with one injector line that has a slip-on brass ferrule on one end. Works just fine. It was put on before we got it. I found it when I was bleeding the injectors one day. Got all discouraged when the line came up out of the nut, but having no other option, I put it back together and it's been running that way ever since.
The Following User Says Thank You to Jim Rankin For This Post:
I just purchased this oiler... Matt McGivney Antique Gas Engine Discussion 19 11-17-2009 09:53:46 PM
Your Cheapest Purchased Engine LCJudge Antique Gas Engine Discussion 83 03-28-2009 03:22:51 PM
JUst purchased Hercules macktractor Antique Gas Engine Discussion 2 09-11-2006 09:01:34 AM
Tractors purchased and NOT picked up Ihorse Antique Gas Engine Discussion 13 07-19-2005 08:29:55 PM
EK Mg purchased from Jim White Chuck Martin Antique Engine Archives 1 04-27-2003 06:27:28 AM
