Onan DJB Genset - Just Purchased
this thread has 26 replies and has been viewed 4226 times
Old 12-02-2014, 12:01:17 AM
thmecharlie thmecharlie is offline
Default Re: Onan DJB Genset ,Just Purchased
Hi Max Could you send me the Manual #967-500 my JB magiciter is having trouble putting out to much juice about 150 volts instead of 120. it is 3 phase 208 supposed. Thanks!
Old 12-02-2014, 01:42:11 AM
Default Re: Onan DJB Genset - Just Purchased
Is it running at 1800 rpm?? They do not have a voltage regulator.. regulated by the engine rpm..
  #23
Old 12-02-2014, 02:07:39 AM
Doug Reed Doug Reed is offline
You can download the Magneciter manuals from this thread:
Magneciter info complete?
http://www.smokstak.com/forum/showthread.php?t=139227 (post#11)
Do you have all the DJB (spec A-AC) manuals?
967-0121 Operator's manual
967-0221 Parts manual
967-0751 Engine Service manual
967-0500 (spec A-P?) Magneciter gen-end
900-0184 (spec AA-AC) YD generator end
The Following User Says Thank You to Doug Reed For This Post:
  #24
Old 04-16-2018, 10:25:40 PM
JohnnyC JohnnyC is offline
Blowing the dust off of this thread.
This past weekend I met Keeper and is author of this thread and owner of a 6.0 DJB.
Long story short, Keeper bought an Onan 6.0 DJB from a government deal auction site in 2011. The DJB was made in 1972. Keeper had it running and making electric and was checked to be in perfect working order by a local generator company, but mice moved into the control box, chewed up and pissed in the control box which ruined many of the components many years ago.
Keeper rewired the control box, but something went wrong. When he connected the battery a relay in the control box would rapidly chatter and has not pursued fixing it at that point. The last time the DJB ran was in 2012.
The DJB was thrown on CL and I answered the ad since he lives only minutes away. We chatted a while on the phone and he would really like to get it running again, but he admitted that wiring is not one of his strong points. I agreed to run over to his house and check it out. Not knowing what to expect I only brought a Big Fooken Battery (a gift to Keeper) and my Fluke. I did not spend too much time since it was near freezing, but I snapped pictures to closely examined the control box on my PC and share with the group. We eventually got the DJB to crank over which was the first time since 2012, but we did not put full effort to start it due to several issues. Cranking sounded VERY HEALTHLY!
Some of the issues that need to be resolved are two unattached wires which a good/clear schematic will help. Second, all wires need to be gone over using a schematic. The DJB cranks when the start/stop toggle switch is toggled to both the start and stop positions, clearly a problem.
Keeper has a schematic, but it is extremely blurry making it very difficult to read. I will download manuals including schematic.
I shot a quick video showing the problems that need to be resolved which can be seen in the following link ---> https://www.youtube.com/watch?v=yHW2H8uCDx0
In addition I attached several pictures below showing the control box and loose wires. Once I obtain a clear schematic to figure out were the 2 loose wires go as well as a guide to checkout the wiring in general, I will return for "round two". Keeper's 6.0 DJB is a "keeper" if we can get it to run.
JohnnyC
New Jersey
ID:	308440   Click image for larger version
ID:	308441   Click image for larger version
ID:	308442   Click image for larger version
The Following 5 Users Say Thank You to JohnnyC For This Post:
  #25
Old 04-17-2018, 06:59:49 AM
Kevin K Kevin K is offline
Our library of Onan documentation has tremendously improved since this thread was started in 2011. I hope the wiring diagram is better than what Keeper has.
The Following 4 Users Say Thank You to Kevin K For This Post:
  #26
Old 04-17-2018, 07:34:57 AM
PopsGarage PopsGarage is offline
Johnny, I have a MDJB 6kw If all three glow plugs are not working it will not start mine needs 30 seconds minimum temp below 3o degf I will cycle the heaters twice, crack the fuel lines to purge any air out
Bob
Old 04-17-2018, 08:37:48 AM
Bob
Hi Bob. He is not ready to start it yet. After he rewired the DJB's control box it just buzzes from the relay seen in the video when the battery is connected. If the start/Stop toggle switch is toggled to both the start and stop positions it will cause the starter the engage. Also, there are 2 wires that are not connected in the control box. One of the wires is a thicker wire that leads to the generator head with no markings. In the video it is labeled with a "15", but the label was put on by Keeper and the number was for Keepers notes only, not for the schematics numbering.
JohnnyC
New Jersey
---------- Post added at 08:37:48 AM ---------- Previous post was at 08:35:13 AM ----------
Many thanks Kevin. The information will be of great help.
JohnnyC
New Jersey
I just purchased this oiler... Matt McGivney Antique Gas Engine Discussion 19 11-17-2009 09:53:46 PM
Your Cheapest Purchased Engine LCJudge Antique Gas Engine Discussion 83 03-28-2009 03:22:51 PM
JUst purchased Hercules macktractor Antique Gas Engine Discussion 2 09-11-2006 09:01:34 AM
Tractors purchased and NOT picked up Ihorse Antique Gas Engine Discussion 13 07-19-2005 08:29:55 PM
EK Mg purchased from Jim White Chuck Martin Antique Engine Archives 1 04-27-2003 06:27:28 AM
