Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Generac Propane 60kW Genset with ATS, help with Identifiying
this thread has 3 replies and has been viewed 183 times
Old 08-21-2019, 05:13:53 PM
micia micia is offline
Photo Generac Propane 60kW Genset with ATS, help with Identifiying
I have a early 80's Generac Propane 60kW genset with built in ATS. The two main control boards are missing, as is the DATA PLATE! I have included pictures of the unit, but no model or serial info. I am in need of the two cards that are missing and need a model #.
Thanks.
Name:	2 Missing control card locations.jpg
ID:	341978   Click image for larger version
Name:	Front of control panel.jpg
ID:	341979   Click image for larger version
Name:	Generator Control card connectors.jpg
ID:	341980   Click image for larger version
Name:	Generac ATS-gen controls.jpg
Old 08-21-2019, 07:21:31 PM
Default Re: Generac Propane 60kW Genset with ATS, help with Identifiying
It's a clean one but it's ancient.
Post a pic of the inside of the ATS section as well.
this is my best guess on the controls:
https://www.radwell.com/en-US/Buy/GENERAC/GENERAC/57547
I think you also need the latch/crank or crank board, maybe 57355 for a latch crank or a 57358 crank board. I can't see anyone has them anywhere.
I'm pretty sure all the cards are obsolete. I've been working on them 11 years and I have never seen one quite like that.
Old 08-21-2019, 11:34:28 PM
Photo Re: Generac Propane 60kW Genset with ATS, help with Identifiying
Here is the inside of the ATS.
Thanks
Old 08-21-2019, 11:34:59 PM
Email NOT Working
Early Generac units were a bit "different". That one is no exception. Very good condition for being so old though. If it was mine and I had a very specific reason to use it I guess I would rip into the wiring and replace it with modern controls. Otherwise, scrap it, sorry to say.
Generac 60KW Diesel 95A 00372-S (1995?) Information Schmalzs Generac Generators (SEARS, etc.) 3 03-05-2018 08:32:35 PM
Generac 2000 60KW NG - Revs UP for 1 second then Down continously. zukiper Generac Generators (SEARS, etc.) 4 05-10-2017 06:59:58 PM
Generac 2000 series 60KW diesel 208-3* to 120/240-1* reconnect? ACFBrill48 Generac Generators (SEARS, etc.) 2 03-20-2017 07:54:28 PM
Generac 60KW 3ph Reconnection A911Pro Generac Generators (SEARS, etc.) 35 07-14-2016 09:36:46 PM
60KW Generac Hunting/Flickering Problem todengine Generac Generators (SEARS, etc.) 2 01-16-2014 09:49:59 PM
